I thought I messed up my switch (maybe I did) but since it works I am guessing it is fine. However, I see strange file size when I command "show flash". The image file looks too small in size (only 512K?), no? That is the size of the file, isn't it? And there is private.config.text renamed (I did not rename it).
Directory of flash:/
2 -rwx 1915 Mar 1 1993 00:01:07 +00:00 private-config.text.renamed
3 -rwx 1913 Mar 1 1993 00:01:07 +00:00 private-config.text
4 -rwx 1993 Mar 1 1993 00:08:41 +00:00 express_setup.debug
594 -rwx 1192 Mar 1 1993 00:01:07 +00:00 config.text
5 drwx 512 Mar 1 1993 01:36:14 +00:00 c2960-lanbasek9-mz.150-2.SE11
591 -rwx 1191 Mar 1 1993 00:01:07 +00:00 config.text.renamed
592 -rwx 3096 Mar 1 1993 00:01:07 +00:00 multiple-fs
27998208 bytes total (11536384 bytes free)
Also when I do "show ver" this is what I get:
Switch uptime is 12 hours, 42 minutes
System image file is "flash:/c2960-lanbasek9-mz.150-2.SE11/c2960-lanbasek9-mz.150-2.SE11.bin"
Switch Ports Model SW Version SW Image
* 1 9 WS-C2960-8TC-L 15.0(2)SE11 C2960-LANBASEK9-M
Is everything looking normal?
I have no problems with the unit. It works fine as it should as far as I can tell.
Thanks.
