Upgrading a 2501 for CCNP LAB?
stevec90
I have a lab with 5 routers. I recently picked up a couple of 2501's with 11.1 IOS. My question is, is it worth the 50 bucks to upgrade the DRAM and Flash so I can install 12.3 IOS? I have 2 2610XM's that will provide good functionality for practice, so I am thinking that it won't matter that much to leave the 2501's at 11.1, since they are mainly just to add hops. Will there be any problems/limitations with having an older IOS?
Steve,
No, I would spend the upgrade money to buy a couple of 2600 instead even if you have to pay a few more $.  They go for about $50 to $70 on Ebay.
Reza
Reza Sharifi
Steve,
The 2500 series routers are very old and you can not upgrade the flash to more then 16M.  It is also a very very slow router (for these days).
and comes with only a 10Mb Ethernet interface and 2 serial. You also have to use and EUI interface to convert the port to RJ45 to be able to use it.
I would look an Ebay for 2600 possibly 2621 which will give you 2 10/100 native Ethernet interfaces.
The 2522 it is a good choice if you want to build a frame-relay and the 2509 and 2511 are good as terminal servers.
Reza
Reza, I already have the routers in my lab. I had a couple of extra transceivers also, so I am set on that, and speed is not an issue - I'm studying for my CCNP.  16/16 is the max, but 16/16 is all you need for the 12.3 IOS. So my question is, is it worth it to upgrade the memory for the 12.3 IOS?
Steve,
Reza
Is this becuase the 11.1 IOS has pretty much the same commands as the 12.3 IOS? I have heard to get the "latest and greatest" IOS to be compatible with CCNP studies, why is that if they are essentially the same?
