Upgrading IOS on a stack
Chris Pohlad-Thomas
So it looks fairly straightforward on upgrading the IOS on switches in a stack based on this:
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00804799d7.shtml#cfbin1
I am assuming that it is important to make sure that each member of the stack gets the bin file copied to it's respective flash. For example in our case we have switches 1, 2, 4, 5, so we would make sure the bin file was on flash1, flash2, flash 4 and flash 5?
Then we can do the
boot system switch all flash:/
command?
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
That's the procedure I normally use.
Joseph W. Doherty
Disclaimer
Posting
Yes, copy IOS images to all the stack member switches flash by using
copy tftp: flash1:
copy tftp: flash2:
.... etc
Now boot all the flash by using
and write the image... write memeory.
verify OS images by issuing the command show boot
~Hari
Disclaimer
Posting
copy tftp: flash1:
copy tftp: flash2:
BTW, an alternative to what Hari has, once you get the BIN image on one flash you can copy from that flash to any of the others.  I.e. copy flash#: flash#:
dynamitec1
Thank you, Hari!
