I have experienced the following problem on gigabit interfaces, I hope that you can help me solve this one.
00:00:09: %RP-4-DOWNREV_FABLDR: Slot 4 ROM fabldr too old; downloading from bund
le
00:00:09: %RP-4-DOWNREV_FABLDR: Slot 5 ROM fabldr too old; downloading from bund
le
00:00:11: %RP-4-DOWNREV_FABLDR: Slot 6 ROM fabldr too old; downloading from bund
le
00:00:11: %RP-4-DOWNREV_FABLDR: Slot 7 ROM fabldr too old; downloading from bund
le
the IOS is the newest one - gsr-k4p-mz.120-30.S.bin
it doesn't accept the upgrade command
outer#upgrade all
Linecard in slot 4 is not enabled; skipping
Linecard in slot 5 is not enabled; skipping
Linecard in slot 6 is not enabled; skipping
Linecard in slot 7 is not enabled; skipping
Thanks in Advance,
Mesut
