Retrieving 1760 serial number remotely?
asmith
There has got to be a way to retrieve routers serial number remotely?
Anybody know answer? If so please direct me....
thanks...
AL
2 Accepted Solutions
thisisshanky
Level 11
Level 11
Unless the router was preconfigured with the "snmp-server chassis-id " command, you wont be able to retrieve it remote. You will have to read it off the box.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
snmp-server community public ro
snmp-server community private rw
public and private are the read only as well as read write communities.
Sankar Nair
9 Replies 9
Hello Al,
there is a way to do this with SNMP, check the link to the document below:
How To Collect Chassis Information (including the Chassis Serial Number) For Routers And Catalyst Switches Using SNMP
http://www.cisco.com/en/US/partner/tech/tk648/tk362/technologies_tech_note09186a0080094a9a.shtml
HTH,
Georg
Georg, thanks for the info, for some reason evreytime i click on the link, it goes to a log on page, i enter cco info and then
http: prohibited page, username passowrd invalid...
but yet i'm already logged in? wierd..
Hey liked reading about your career in netpro article,
AL
thisisshanky
Level 11
Level 11
Sankar Nair
Thanks.. I'm new to cisco iso's, how do you get "snmp" turned on in routers?
thanks...
AL
Sankar Nair
anand
you can find the Router serial #, chasis #, motherboard serial # by typing "show version"
Serial number of chassis is not displayed by show version. You get the motherboard serial number.
Sankar Nair
muca
Level 3
Level 3
Depending on IOS version you can try the show inventory command.
Murilo's suggestion is a good one! You can check that out. More details here.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00801d2d6d.html
Sankar Nair
