Urgent help needed for VoIP Natting on 1841
starpoint09
ip http server
ip http secure-server
no ip nat service sip udp port 5060
ip nat inside source list 1 interface FastEthernet0/0/0 overload
ip nat inside source list 101 interface FastEthernet0/0/0 overload
ip nat inside source list 103 interface FastEthernet0/0/0 overload
ip nat inside source static udp 192.168.1.154 5060 66.128.121.27 5060 extendable
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 2 remark RDP To Domain Server
access-list 70 permit 192.168.1.0 0.0.0.255
access-list 101 permit tcp any any eq 4004
access-list 102 permit ip any any
access-list 102 deny   tcp any any eq 22
access-list 103 remark CCP_ACL Category=18
access-list 103 permit udp any any range 10000 20000
access-list 103 permit tcp any any eq 5222 established
access-list 103 permit udp any any eq 5060
access-list 110 permit udp any any range 10000 20000
Ok  I am at a loss  Probably something dumb  but i cant get sip signaling back on port 5060   Audio is good tho.  Any idea would be urgently welcome as the voice pbx is down.
paolo bevilacqua
First the access list used seems to be wrong, establisehd is not used in NAT ACL.
Second, by disabling SIP-ALG, things are unlikely to work
Then, can you explain in other words what is the problem that  you are xpereincing?
Finally, if you need guaranteed, time bound support get a smartnet contract, as this is a free forum.
starpoint09
5222 establied is for a data stream  that goes between an IM system with teh PBX
Not Getting Sip Signalling back from the carrier.
That is very possible since you disabled sip-alg, you're sending out private IP address and so thye are not responding.
