urgent help needed
musama01
hi i attached file below. problem is that i connent to lans via router and config each and every thing again n again but the problem is data is sharing between lans but not to other lan network. urgent help will be appreciated.
your IP addressing was not entirely correct. For the sake of simplicity, I added DHCP pools, as well as the correct IP address assignments. Attached the revised file...
