urgent < issues with POS link >
pushkar1782
following is the output . Kindly suggest i m facing high latency issues...
sh controllers pos 3/0/0
POS3/0/0
SECTION
LOF = 0 LOS = 0 BIP(B1) = 0
LINE
AIS = 0 RDI = 0 FEBE = 137440441 << BIP(B2) = 0
PATH
AIS = 0 RDI = 0 FEBE = 0 BIP(B3) = 0
LOP = 0 NEWPTR = 0 PSE = 0 NSE = 1015695 <<<<<
Active Defects: None
Active Alarms: None
Alarm reporting enabled for: SF SLOS SLOF B1-TCA B2-TCA PLOP B3-TCA
BER thresholds: SF = 10e-3, SD = 10e-6
TCA thresholds: B1 = 10e-6, B2 = 10e-6, B3 = 10e-6
APS
COAPS = 0 PSBF = 0
State: PSBF_state = False
Rx(K1/K2): 00/00 Tx(K1/K2): 00/00
S1S0 = 02, C2 = 16
CLOCK RECOVERY
RDOOL = 0
State: RDOOL_state = False
PATH TRACE BUFFER: STABLE
Remote hostname : LONCR1.re0 so-7/0/1
Remote interface:
Remote IP addr :
Remote Rx(K1/K2): / Tx(K1/K2): /
BER thresholds: SF = 10e-3 SD = 10e-6
TCA thresholds: B1 = 10e-6 B2 = 10e-6 B3 = 10e-6
Clock source: line
POS3/0/0 is up, line protocol is up
Hardware is Packet over Sonet
Description: --- To FT IAR - IPBW = 622Mbps
Internet address is 81.52.136.49/30
MTU 4470 bytes, BW 622000 Kbit, DLY 100 usec,
Encapsulation HDLC, crc 32, loopback not set
Keepalive set (10 sec)
Scramble enabled
Last input 00:00:03, output 00:00:00, output hang never
Last clearing of "show interface" counters 12:45:20
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 2677000 bits/sec, 944 packets/sec
5 minute output rate 52000 bits/sec, 12 packets/sec
47434951 packets input, 8763137062 bytes
Received 4617 broadcasts (0 IP multicast)
0 parity
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
3033544 packets output, 1048575972 bytes, 0 underruns
0 output errors, 0 applique, 0 interface resets
0 carrier transitions
8 Replies 8
network.king
Level 4
Level 4
There is no interface specific configuration that could cause high latency unless you have configured some small bw and done QOS , but here BW is also fine .Usually the issue would be with the provider , might be taking a different route for your circuit or some issues with his network.
Once try giving a shut and no shut or try changing the cable and last ask the provider to check the issue in his network
regards
vanesh k
Plz note
FEBE , and NSE errors are increasing ..any suggestions on it ..
Please check below links :
http://www.cisco.com/en/US/tech/tk482/tk607/technologies_tech_note09186a008009464b.shtml
According to the link, the NSE = Write into buffer is performed faster than read from buffer. The clock slips indicate that the clock rate on the incoming interface is not synchronized somehow with the clock rate on the outgoing interface.
Try to check the clock.
More from below :
http://www.cisco.com/en/US/tech/tk482/tk611/technologies_tech_note09186a008014f349.shtml#ais
The FEBE means the device on the other end of this link has B2 or B3 errors, and reports the errors back to router A to indicate errors that come either from router A or the link.
You can carry the hard loopback test to identify the problem.
Sorry for not familiar on POS and try to source the info. to help.
Hope this helps.
yeah,
thats the link i hv already reffered . Thanx for help .
bye
hey guys ,
i hv got my last mile fibre patch changed ..this solve FEBE errors but again NSE errors on show controllers pos3/0/0 are increasing .
can you plz help ? i've read NSE are becoz of clocking issues with PTT ( clocking slips )
but clocking on router + PTT router is line ..
Do you mean both PTT & your router are using clock from line ? If yes, it is also the PTT issue. I have no idea is there any limitation on the POS in clock issue. Please try if it can check the clock (rate, source, etc.) and try to bring the line up to provide the service to the customer then troubleshoot the problem by collecting more information.
Hope this helps.
see the pos line is already up .and everything is disapperared....
i got the PTT router ( IAR ) to change their clocking to Line , our end router clocking to line.
NSE ,FEBE errors now disappered..yes it was a clocking issue.
It is good that you solved the problem. :)
