usage of port forwarding
techguy
Level 4
Level 4
Hi peeps,
Can anyone tell me the exact usage of port forwarding (when, why, where & how)?
Thanks.
Joseph Nelson
Port forwarding is just PAT ( port address translation), a form of NAT. Suppose you have a web server sitting behind a firewall or router, the web server has IP 1.1.1.1/24 and listens on port 8080. Your routers outside interface is 2.2.2.2/24.
Assume no NAT is being performed, users on the internet can access 1.1.1.1 directly. User fires up a browser and browses to 1.1.1.1-- it whats to talk to your web server on port 80. But your server is listening on port 8080. Your router needs to forward request for 1.1.1.1:80 to 1.1.1.1:8080. That is port forwarding. Generically its a form of PAT ( port address translation).
Another example is where you have webserver1 and webserver2. Both are listening on port 80 but are addressed with private IPs. Assume you use static NAT to translate the two webserver private IPs to a single public IP. How does the router know which server to send the traffic to if a request comes in for port 80? The answer is port forwarding. In this case, you could forward port 8081 to webserver1 and port 8082 to webserver2. Now when a user fires up a browser they can type http:1.1.1.1:8081 to hit webserver1. Likewise, they type http://1.1.1.1:8082 to hit webserver2.
Joe
Rate if helpful
Joseph Nelson
Joe
Rate if helpful
thank you very much...
