USB Interface
Mero Cisco
Does any router supports USB as an interface? I have got an EVDO Wireless Data Card with USB. I can use the device to surf net on laptop, I want to connect HO through EVDO card, can I connect it to any router and do VPN.
Mero
paolo bevilacqua
As asked before in this forum (use search function):
No, USB interfaces on IOS routers cannot be used to connect any kind of data interface.
Leo Laohoo
I agree with Paolo.
The USB port of the routers, switches and ASA are used only for file transfers and not a way to connect a client.
