Bookmark
Subscribe
1566
USB port in cisco 892K
Bikas Giri
HI,
What is the use of USB port in cisco 892K router ?
Bikas
Ivan Krimmel
Level 7
Level 7
Hey Bikas,
it has multiple uses:
• Two USB 2.0 ports for security eToken credentials, booting, and loading configuration from USB
check this http://www.cisco.com/en/US/prod/collateral/routers/ps380/data_sheet_c78-519930.html
Cheers,
Ivan.
Thanks Ivan,
Where can I find the technical detail/command reference for it's use.
With best regards,
Bikas
