Use bandwidth of VAI in QoS Parent Policy
Scott Pettit
Level 9
Level 9
Hi all,
Have been trying to solve this myself for a couple of days but haven't managed to find an answer.  I've done a similar solution before where I put bandwidth inherit on the Dialer interface of the CPE and it inherited the ATM interface speed (the upload sync rate) and prevented the CPE from maxing out and hitting hardware queuing in the DSLAM.  I can't seem to find a way to do this downstream from our ASR1K to the customer though.
Platform is ASR1001 with IOS 3.7.2 or 15.2(4)S
Problem description:
We have many xDSL users (ADSL2+ and VDSL2).  They all sync at different speeds depending on how far they are from the DSLAM.
Example:
Customer A might be connected at 40000kbps/10000kbps (VDSL2)
Customer B might be connected at 5000kbps/600kbps (ADSL)
When they connect and the PPPoE session comes up, the bandwidth on the Virtual Access Interface is equal to the customer's downstream sync rate, so Customer A's virtual access interface, Virtual-Access 2.13 will say 40000kbps, and Customer B's virtual access interface Virtual-Access 2.39 will say 5000kbps.
Using RADIUS, we apply a sub-qos-policy-out to the PPPoE session.
I want to shape the customer to 80% of their sync rate so that we do not hit interface congestion in the DSL network which makes VoIP perform poorly.
I cannot use an absolute value for the shape, because the sync rate varies for each customer.
The problem I have is at present the policy-map is using the interface bandwidth of Gi0/0/1 (1Gbit) instead of the bandwidth of the Virtual Access Interface.  Therefore the customer is being limited to 800Mbit which means the QoS policy will never take effect.
RADIUS Config Below:
cisco-avpair += ip:sub-qos-policy-out=QOS-POLICY-OUT-PARENT-DSL
Class Maps
class-map match-any QOS-CLASS-VOIP-RTP-DSL
match protocol rtp audio
match access-group name QOS-VOIP-RTP
class-map match-any QOS-CLASS-VIDEO-RTP-DSL
match protocol rtp video
Policy Maps
policy-map QOS-POLICY-OUT-CHILD-DSL
class QOS-CLASS-VOIP-RTP-DSL
  priority percent 5
class QOS-CLASS-VIDEO-RTP-DSL
  priority percent 10
class class-default
  fair-queue
policy-map QOS-POLICY-OUT-PARENT-DSL
class class-default
  shape average percent 80
   service-policy QOS-POLICY-OUT-CHILD-DSL
Output of Show Interface Vi2.44
show int vi2.44
Virtual-Access2.44 is up, line protocol is up
  Hardware is Virtual Access interface
  Interface is unnumbered. Using address of Loopback4000
  MTU 1500 bytes, BW 48422 Kbit/sec, DLY 100000 usec,
     reliability 255/255, txload 5/255, rxload 1/255
  Encapsulation PPP, LCP Open, multilink Closed
  Open: IPCP, IPV6CP
  PPPoVPDN vaccess, cloned from AAA, AAA, Virtual-Template1
  Vaccess status 0x0
  Protocol l2tp, tunnel id 51815, session id 24465
  Keepalive set (60 sec)
     246037 packets input, 285563771 bytes
     141575 packets output, 18807810 bytes
  Time to interface disconnect:  idle 00:29:58
Output of Show Policy-Map on Virtual Access Interface
show policy-map interface vi2.44
Virtual-Access2.44
SSS session identifier 1011 -
  Service-policy output: QOS-POLICY-OUT-PARENT-DSL
    Class-map: class-default (match-any)
      105059 packets, 18013377 bytes
      30 second offered rate 217000 bps, drop rate 0000 bps
      Match: any
      Queueing
      queue limit 555 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 104996/19900029
      shape (average) cir 800000000, bc 3200000, be 3200000
      target shape rate 800000000
      Service-policy : QOS-POLICY-OUT-CHILD-DSL
        queue stats for all priority classes:
          Queueing
          queue limit 512 packets
          (pkts output/bytes output) 0/0
        Class-map: QOS-CLASS-VOIP-RTP-DSL (match-any)
          0 packets, 0 bytes
          30 second offered rate 0000 bps, drop rate 0000 bps
          Match: protocol rtp audio
          Match: access-group name QOS-VOIP-RTP
          Priority: 5% (40000 kbps), burst bytes 1000000, b/w exceed drops: 0
        Class-map: QOS-CLASS-VIDEO-RTP-DSL (match-any)
          0 packets, 0 bytes
          Match: protocol rtp video
          Priority: 10% (80000 kbps), burst bytes 2000000, b/w exceed drops: 0
          Match: any
          Queueing
          (queue depth/total drops/no-buffer drops/flowdrops) 0/0/0/0
          Fair-queue: per-flow queue limit 138 packets
Output of Show Run Interface Vi2.44
show run int vi2.44
Building configuration...
Current configuration : 257 bytes
interface Virtual-Access2.44
ip flow ingress
ip flow egress
ipv6 unnumbered Loopback4000
ipv6 enable
ipv6 mtu 1492
ipv6 nd reachable-time 30
ipv6 nd other-config-flag
no ipv6 nd ra suppress
ipv6 dhcp server PPP-RADIUS
ppp timeout idle 1800
end
This comes off the Virtual-Template 1
interface Virtual-Template1
ip unnumbered Loopback4000
ip flow ingress
ip flow egress
load-interval 30
ipv6 enable
ipv6 mtu 1492
peer ip address forced
no peer default ip address
no snmp trap link-status
keepalive 60
ppp max-configure 3
ppp mtu adaptive
no ppp lcp fast-start
ppp mru match
ppp authentication pap callin pppoe-dialin
ppp authorization pppoe-dialin
ppp ipcp address required
ppp ipcp no-renegotiation
ppp multilink
ppp timeout retry 8
ppp timeout ncp 10
ppp timeout authentication 18
end
Underlying Physical Interface that L2TP Session Comes in on
interface GigabitEthernet0/0/1.4003
description L2TP Tunnel
encapsulation dot1Q 4003
vrf forwarding XXXXXXX
ip address XXXXXXX 255.255.255.252
7 Replies 7
tim
I've actually asked TAC about htis very thing. Ticket is still open and I am awaiting for a reply. Will let you know what they say, unless you managed to find a way yourself already?
Hi Tim,
I also have TAC case 624352829 open, so far the engineer hasn't been able to provide a solution...
If anyone from Cisco who does know how to do this is reading, it'd be much appreciated if you could contact the engineer on this case and provide some instruction
-Scott
Chris Rogers
Just wondering if you ever got to the bottom of this with Cisco? I have exactly the same issue.
Chris
Chris,
TAC confirmed that currently it just won't do what is required in the way we are looking at it.
A possible tidy/ish solution they did suggest is to use 'bandwidth qos-reference' applied via RADIUS but they also point out in the same sentance that the ASR1K platform doesn't support that command at all at the moment, let alone via RADIUS.
The only other way to do this is to configure a whole bunch of policy-maps for different speeds and then apply the correct one via RADIUS. For example, you can create a policy-map that shapes your tails at 0.5Mbit or 1Mbit intervals and then use a check attribute in RADIUS to match a range of sync speeds which are handed over to RADIUS in the RADIUS requests sent by the LNS.
For example in freeradius you can do something like this for a test account, repeating the check lines for each of your sync speed ranges and policy maps that you want to use:
user@realm Connect-Info >= "160000\/1000", Connect-Info <= "287000\/1000"
        Cisco-AVPair = "ip:sub-qos-policy-out=135K-POLICYMAP",
        Fall-Through = Yes
user@realm Connect-Info >= "288000\1000", Connect-Info <= "415000\/1000"
        Cisco-AVPair = "ip:sub-qos-policy-out=250K-POLICYMAP",
        Fall-Through = Yes
user@realm Cleartext-Password := "password"
        Framed-IP-Address = x.x.x.x,
        Framed-IP-Netmask = 255.255.255.255,
        Framed-Protocol = PPP,
        Service-Type = Framed-User
This then applies a policy-map to your subscriber interface based on their sync speed which is essentially what we are trying to do. Just not as tidy as we would like to have done it
No we didn't get a solution for this involving the VAI.  We did however add a bunch of parent shapers in 5M increments and gave the customer the ability to control this online up to the max speed of their service.
I thought about what you're suggesting with FreeRADIUS but didn't quite get there - I like that idea though, will give it a go.
The main reason we wanted the VAI bandwidth was to deal with cases where a customer has variable copper in their area resulting in sync rates that change a bit.  We still want them to have a great experience as far as Voice/Video being prioritised and smooth TCP performance.  The RADIUS idea might do that
This can be achieved using FreeRADIUS in a slightly different way to Tim's suggestion.
If you have a parent shaper configured similarly to what you have now, but with an arbitrary shape average value like:
shape average 10000000
you can at login-time substitute the value for shape average with an AV pair like:
Cisco-AVPair += "ip:qos-policy-out=add-class(sub,(class-default),shape(VALUE))
where VALUE is your target shaper bandwidth.
The trick is to get the bandwidth from Connect-Info via a regex in FreeRADIUS then return an AV pair in the response. This can be done in post-auth (under sites-enabled/default or wherever) with the following code:
if ( "%{reply:Cisco-AVPair[*]}" =~ /ip:sub-qos-policy-out=QOS-POLICY-OUT-PARENT-DSL/ ) {
        if ( "%{request:Connect-Info}" =~ /[^\/]*/ ) {
            update reply {
                Cisco-AVPair += "ip:qos-policy-out=add-class(sub,(class-default),shape(%{0}))"
The first line checks for the existence of the policy in the Cisco-AVPair list that has been returned already by authenticating against your SQL DB. If we have that, then we read the Connect-Info AV pair from the request, regex it to return only the value on the left-hand of the "/" then insert this value into an AV pair to be returned.
bhwillis
if "bandwidth qos-reference" on the virtual-template is not available in the IOS on your box (and it's not available in the most recent/advanced version), then the "add-class" syntax ("radius-based policing") might work for you:
https://supportforums.cisco.com/docs/DOC-19702
http://www.cisco.com/en/US/docs/ios-xml/ios/isg/configuration/15-1s/isg-radius-pol.html
https://supportforums.cisco.com/thread/2223937
The documentation is not very good & the syntax is horrible, but it's there.  When I tried it on our boxes it removed all the QoS from the virtual-access, but there are others for whom it seems to have worked.
Best of luck.
