Username always in capitlaized letters
waschminator
Hello, i have a weird issue on an old 3945 router...
every user that i insert locally has capitalized letters. even if a configure it in small letters in the configuration it appears with capitalized letters. also the login is just available per capitalized letters.
"username ADMIN secret"
any ideas how i can change that?
br + thx
balaji.bandi
The router end of Life long back - as i remember this is BUG - but i am not able to view the bug since the product end of Life.
User-name is stored as Uppercase always in IOS regardless of config
CSCuh24317
BB
5 Replies 5
balaji.bandi
CSCuh24317
BB
                                 >....but i am not able to view the bug since the product end of Life.
 @balaji.bandi FYI :           https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuh24317
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Cheers - some what not able to view myself.
BB
waschminator
great, thanks a lot for your feedbakc. will do an upgrade
the upgrade has solved the issue. thx
