using a printer in a different vlan
roncro
Level 3
Level 3
I have seen several post about this topic in the pas, but how does one have machines in one vlan use printers in another vlan. (I can see/ping both from the router, the printer as well as the work stations, workstations are in vlan1 and the printer is in vlan3)
Is there a way to have machines in one vlan only being able to 'touch' the printer, and nothing else? (iif there were other devices in that vlan?)
thanks,
Ron
Right. If you have IP connectivity, you should be able to go from there...
13 Replies 13
omz
You can configure an ACL to allow access to only printer IP.
something like -
access-list 101 permit ip any 10.1.1.1 0.0.0.0
where 10.1.1.1 is a printer IP
not really sure what you are after...a printer is just a device with an IP address. As long as that IP address is reachable from any other Vlan, printing across Vlans should work...
Can you clarify ?
well there are a few devices, printer, scanner etc, that I would like to put in a different vlan and have machines from other vlans use the printer but not necessarily the rest.
I have the wireless printer connection through an AP, on vlan3, and I can ping it from the router. The workstations are on vlan1, and I can ping those from the router too. (would I need to put the workstations in vlan3 as well)
Ron
what does your topology look like, which devices do you have in your network ? Is inter-Vlan routing already done somewhere ?
Hello Georg,
well;  physcally it is a 2900 Cisco router and two 2960s switches.  It is a router on a stick setup, with a trunk going from one switch to the router and a trunk between the two switches. (well and there's a RV320, that I just use as a switch for an access point that connects a controller that doesn't like to play well with the cisco 2900 router, but does with the rv320)
VLAN wise;
I have 3 vlans (4,5 and 6 over wireless access points) for 3 different type of sensors
I have one vlan (7, also over wireless, for laptops etc.)
One vlan where I want things like a printer in (vlan 3, also over wireless)
and there's vlan1,  wired.
Inter vlan routing, to be honest I don't know if I have done that all correctly.  I have traffic between vlans but that's all on trunks.
for example one access point is connected to a switch like:
interface GigabitEthernet1/0/12
switchport trunk native vlan 37
switchport trunk allowed vlan 1,3-7,37
switchport mode trunk
while I have a machine in vlan2 connected like:
description zonem.localdomain switch port
switchport trunk native vlan 2
switchport trunk allowed vlan 2,4-7
probably not ideal, if not just wrong.
Ron
if you have configured a router on a stick, there should be subinterfaces for all Vlans. If configured correctly, all Vlans should be able to talk to each other. Can you post the running configuration of the 2900 router ?
Hello Georg,
I have interfaces  for all vlans/subnets on the router I think.
Here's the running config.
thanks!.
#show run
Building configuration...
Current configuration : 6541 bytes
! Last configuration change at 18:30:25 UTC Mon May 18 2020 by admin
! NVRAM config last updated at 23:15:34 UTC Sun May 17 2020 by admin
version 15.4
service password-encryption
hostname Charon
boot-start-marker
boot-end-marker
enable secret 5 $1$Y6Ap$foIYqVqbcci.b9/iOKKVt/
no aaa new-model
no ip dhcp conflict logging
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp excluded-address 192.168.2.1 192.168.2.10
ip dhcp excluded-address 192.168.4.1 192.168.4.10
ip dhcp excluded-address 192.168.5.1 192.168.5.10
ip dhcp excluded-address 192.168.6.1 192.168.6.10
ip dhcp excluded-address 192.168.7.1 192.168.7.10
ip dhcp excluded-address 192.168.3.1 192.168.3.10
ip dhcp ping timeout 600
ip dhcp pool VLAN1-POOL
import all
origin file tftp://192.168.2.8/dhcp/static-bindings-hw-1
default-router 192.168.1.1
dns-server 192.168.1.1
domain-name localdomain
ip dhcp pool VLAN4-DCH-S
import all
origin file tftp://192.168.2.8/dhcp/static-bindings-hw-4
ip dhcp pool VLAN5-WMO-POOL
import all
origin file tftp://192.168.2.8/dhcp/static-bindings-hw-5
ip dhcp pool VLAN6-TNTN-POOL
import all
origin file tftp://192.168.2.8/dhcp/static-bindings-hw-6
default-router 192.168.6.1
ip dhcp pool VLAN7-THE-MATRIX-POOL
import all
origin file tftp://192.168.2.8/dhcp/static-bindings-hw-7
ip dhcp pool VLAN2-SERVERS
import all
origin file tftp://192.168.2.8/dhcp/static-bindings-hw-2
ip dhcp pool VLAN3-DEVICES-POOL
import all
origin file tftp://192.168.2.8/dhcp/static-bindings-hw-3
default-router 192.168.3.1
ip domain name localdomain
ip host charon.localdomain 192.168.1.1
ip host C2960s-north.localdomain 192.168.1.2
ip host cuda.localdomain 192.168.1.116
ip host seismo.localdomain 192.168.2.4
ip host cnc.localdomain 192.168.1.115
ip host picopod.localdomain 192.168.1.107
ip host picoscope.localdomain 192.168.3.37
ip host cisco-ap7.localdomain 192.168.37.17
ip host cisco-ap8.localdomain 192.168.37.18
ip host cisco-ap2.localdomain 192.168.37.12
ip host north.localdomain 192.168.1.2
ip host cisco-ap1.localdomain 192.168.37.11
ip host cisco-ap9.localdomain 192.168.37.19
ip host cisco-ap5.localdomain 192.168.37.15
ip host C2960s-south.localdomain 192.168.1.3
ip host south.localdomain 192.168.1.3
ip host cisco-ap6.localdomain 192.168.37.16
ip host AP-TM-W-F7C033.localdomain 192.168.1.5
ip name-server 75.75.75.75
ip name-server 75.75.76.76
ip cef
no ipv6 cef
cts logging verbose
license udi pid CISCO2911/K9 sn FCZ192771UU
username admin privilege 15 password 7 1500085A550A3F373D3D342F1A5441
username wwwadmin privilege 15 password 7 061118365E4D5F48251B130500
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description WAN
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description LAN
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.1
encapsulation dot1Q 1 native
ip helper-address 192.168.2.255
ip nat inside
interface GigabitEthernet0/1.2
encapsulation dot1Q 2
ip address 192.168.2.1 255.255.255.0
ip helper-address 192.168.1.1
ip directed-broadcast
ip nat inside
interface GigabitEthernet0/1.3
encapsulation dot1Q 3
ip address 192.168.3.1 255.255.255.0
interface GigabitEthernet0/1.4
encapsulation dot1Q 4
ip address 192.168.4.1 255.255.255.0
interface GigabitEthernet0/1.5
encapsulation dot1Q 5
ip address 192.168.5.1 255.255.255.0
interface GigabitEthernet0/1.6
encapsulation dot1Q 6
ip address 192.168.6.1 255.255.255.0
interface GigabitEthernet0/1.7
encapsulation dot1Q 7
ip address 192.168.7.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.37
encapsulation dot1Q 37
ip address 192.168.37.1 255.255.255.0
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1/0
no ip address
interface GigabitEthernet0/1/1
no ip address
interface GigabitEthernet0/1/2
no ip address
interface GigabitEthernet0/1/3
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
ip forward-protocol udp discard
ip http server
ip http authentication local
ip http secure-server
ip dns view default
domain list localdomain
ip dns server
ip nat inside source list 101 interface GigabitEthernet0/0 overload
ip nat inside source list 102 interface GigabitEthernet0/0 overload
ip nat inside source list 107 interface GigabitEthernet0/0 overload
ip nat inside source static tcp 192.168.x.y 80 interface GigabitEthernet0/0 80
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 102 permit ip 192.168.2.0 0.0.0.255 any
access-list 107 permit ip 192.168.7.0 0.0.0.255 any
control-plane
line con 0
logging synchronous
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password 7 105C0A4F54370618190A2B262D7B64
login local
transport input ssh
line vty 5 392
password 7 131714445A2C10393E2A293E3C7144
login local
transport input ssh
scheduler allocate 20000 1000
ntp master
ntp update-calendar
ntp server time.nist.gov
end
what if you put the printer on a switchport, configure the port as:
switchport mode access
switchport access vlan x
spanning-tree portfast
and set the printer to DHCP, does it get an IP address ? That address should be reachable from all other Vlans. The router on a stick looks correct.
well,  that printer doesn't have a regular ethernet port, it has wireless and USB
However, it does get an ip address and if I put a laptop in that same (wireless) vlan,  I can get to it. (I can also ping it from the router and both switches, and I see it in the association list on the AP). the IP settings seem ok (ip address 192.168.3.37, netmask is 255.255.255.0 and the default gateway is 192.168.1.1, which is the router)
The port (on the switch) of the access point the printer connects through looks like this:
description switch port for AP2
thanks,
Ron
Hello.
--> ip address 192.168.3.37, netmask is 255.255.255.0 and the default gateway is 192.168.1.1, which is the router)
I guess you mean to say the default gateway is 192.168.37.1 ?
Can you ping 192.168.3.37 from any other device (laptop,PC) ?
I am kind of lost to be honest on what the problem actually is. You need to have IP connectivity. The router is configured correctly, the printer gets an IP address...
-->  I guess you mean to say the default gateway is 192.168.37.1 ?
No I meant 192.168.3.1, but somehow it was 192.168.1.1
I can ping it now...     (So now it's just the standard printer hassle...)
thanks!
Ron
I wonder if there's something strange going on,  since I can ping a windows laptop in vlan3 connecting through the same accesspoint from my 'regular' workstation.
Ron
