Need help getting out of the network
nicholasshields
I am fairly new to setting up networks but I am currently stuck trying to get out to the external internet. Right now I can ping from my internal network all the way to the gateway on the firewall but I cant can get any farther then that. My LAN network is on the 192.200.14.x.x and vlsm through out then the network my firewall is on the 192.175.20.x network.
R1#sh run
Building configuration...
Current configuration : 4740 bytes
version 15.5
no platform punt-keepalive disable-kernel-core
hostname R1
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
!ip host BKDC 192.200.16.228
ip name-server 192.200.16.228
ip dhcp excluded-address 192.200.14.1 192.200.14.3
ip dhcp excluded-address 192.200.15.254
ip dhcp excluded-address 192.200.16.1 192.200.16.5
ip dhcp excluded-address 192.200.16.126
ip dhcp excluded-address 192.200.16.129 192.200.16.138
ip dhcp excluded-address 192.200.16.190
ip dhcp excluded-address 192.200.16.193 192.200.16.194
ip dhcp excluded-address 192.200.16.222
ip dhcp excluded-address 192.200.16.225 192.200.16.228
ip dhcp excluded-address 192.200.16.238
ip dhcp excluded-address 192.200.16.241 192.200.16.244
ip dhcp excluded-address 192.200.16.254
ip dhcp pool GUEST-TEST-1
network 192.200.14.0 255.255.254.0
default-router 192.200.15.254
dns-server 192.200.16.228
domain-name SEAM.local
lease 1 1 10
ip dhcp pool WAREHOUSE-LAN-2
network 192.200.16.0 255.255.255.128
default-router 192.200.16.126
lease 1 1 10
ip dhcp pool OFFICE-LAN-3
network 192.200.16.128 255.255.255.192
default-router 192.200.16.190
lease 1 1 10
ip dhcp pool W_AP1
host 192.200.16.3 255.255.255.128
client-identifier 01e0.63da.33c8.69
ip dhcp pool W_AP2
host 192.200.16.4 255.255.255.128
client-identifier 01e0.63da.33b8.f4
ip dhcp pool T/G_AP1
host 192.200.14.3 255.255.254.0
client-identifier 01e0.63da.33da.40
subscriber templating
license udi pid ISR4321/K9 sn FDO21080T13
license boot suite FoundationSuiteK9
license boot suite AdvUCSuiteK9
redundancy
mode none
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
description ****ROUTER ON A STICK INTERFACE*****
no ip address
negotiation auto
interface GigabitEthernet0/0/0.5
description ****G/T WIFI and WIRED****
encapsulation dot1Q 5
ip address 192.200.14.1 255.255.254.0
ip nat inside
standby 5 ip 192.200.15.254
standby 5 priority 200
standby 5 preempt
interface GigabitEthernet0/0/0.10
description ****WAREHOUSE****
encapsulation dot1Q 10
ip address 192.200.16.1 255.255.255.128
ip nat inside
standby 10 ip 192.200.16.126
standby 10 priority 200
standby 10 preempt
interface GigabitEthernet0/0/0.15
description ****OFFICE****
encapsulation dot1Q 15
ip address 192.200.16.129 255.255.255.192
ip nat inside
standby 15 ip 192.200.16.190
standby 15 priority 200
standby 15 preempt
interface GigabitEthernet0/0/0.20
description ****RESALE/EVAL****
encapsulation dot1Q 20
ip address 192.200.16.193 255.255.255.224
ip nat inside
standby 20 ip 192.200.16.222
standby 20 priority 200
standby 20 preempt
interface GigabitEthernet0/0/0.25
description ****SERVER CLOSET****
encapsulation dot1Q 25
ip address 192.200.16.225 255.255.255.240
ip nat inside
standby 25 ip 192.200.16.238
standby 25 priority 200
standby 25 preempt
interface GigabitEthernet0/0/0.30
encapsulation dot1Q 30
ip address 192.200.16.241 255.255.255.240
ip nat inside
standby 30 ip 192.200.16.254
standby 30 priority 200
standby 30 preempt
interface GigabitEthernet0/0/1
description ****WAN INTERFACE****
ip address dhcp
ip nat outside
ip access-group TEST_WAN in
standby 2 priority 200
standby 2 preempt
negotiation auto
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
router rip
version 2
network 192.200.0.0
default-information originate
no auto-summary
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
banner login ^CAuthorized Personnel Only! Please enter your username and password.^C
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
luis_cordova
Spoiler
Hi @nicholasshields
It seems that you are missing a default route so that packages with an unknown destination can go to the internet.
ip route 0.0.0.0 0.0.0.0 dhcp
I also see that NAT is applied to interfaces, but you do not have configured the traffic that will be nated
Hi should the configuration look something along the lines like this?
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
no ip http server
access-list 1 permit 192.200.0.0 0.0.1.255
Hi @nicholasshields
Correct, you could try that setting.
You only have to change the exit interface, because that must be the one that points to the internet.
ip nat inside source list 1 interface Gi 0/0/1 overload
ip address dhcp
ip nat outside
ip access-group TEST_WAN in <---You have applied an ACL, but I don't see the arguments for that ACL. If you are not using it, it would be best to remove this line
standby 2 preempt
negotiation auto
Okay I put the new commands in and got rid of the that on error and I was able to ping google from the router but I wasn't able to ping from my laptop.
C:\Users\Nicholas>ping 192.175.20.82<---Can ping WAN interface on the router
Pinging 192.175.20.82 with 32 bytes of data:
Reply from 192.175.20.82: bytes=32 time<1ms TTL=255
Ping statistics for 192.175.20.82:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
C:\Users\Nicholas>ping 8.8.8.8
Pinging 8.8.8.8 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 8.8.8.8:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 32/34/38 ms
SEAM_R1#sh run
Current configuration : 4914 bytes
! Last configuration change at 21:44:31 UTC Mon May 18 2020
version 15.5
hostname SEAM_R1
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
ip host BKDC_SEAM 192.200.16.228
lease 1 1 10
lease 1 1 10
lease 1 1 10
ip dhcp pool W_AP1
ip dhcp pool W_AP2
redundancy
mode none
no ip address
negotiation auto
ip nat inside
standby 5 preempt
ip nat inside
standby 10 preempt
ip nat inside
standby 15 preempt
ip nat inside
standby 20 preempt
ip nat inside
standby 25 preempt
ip nat inside
standby 30 preempt
ip address dhcp
ip nat outside
standby 2 preempt
negotiation auto
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
router rip
version 2
network 192.200.0.0
no auto-summary
ip nat inside source list 1 interface GigabitEthernet0/0/1 overload
no ip http server
control-plane
banner login ^CAuthorized Personell Only! Please enter your username and password.^C
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
