using Fa0 on ISR 1802 as WLAN
ANTONIO DEUS
The router that was used to connect to the internet over ISDN it is not possible, because we have now a Ethernet incoming signal from ISP.
So, anyone can tell if it possible use the Fast Ethernet 0 port in the Cisco ISR 1802 as WLAN instead of ISDN port?
The figure below show what we trying to do.
Thanks in advanced,
António
9 Replies 9
paolo bevilacqua
Yes, of course it is possible.
I try to did a simple thing like a firewall between the 8 fast ethernet 1 to 8, and de fast Ethernet 0, but something it is wrong, because I cannot reach from inside of vlan 30 to outside through the fast Ethernet 0 (the internet), even with ping command
The configuration is the follow:
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
service sequence-numbers
hostname router-fw
boot-start-marker
boot-end-marker
logging buffered 16384 debugging
clock summer-time WET recurring last Sun Mar 2:00 last Sun Oct 2:00
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip domain name xpto.pt
ip ips po max-events 100
login block-for 60 attempts 3 within 15
login on-failure
login on-success
no ftp-server write-enable
spanning-tree portfast bpduguard
archive
log config
  logging enable
  logging size 1000
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface BRI0
no ip address
shutdown
interface FastEthernet0
description Rede Externa
ip address dhcp
no ip unreachables
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
no cdp enable
interface FastEthernet1
description Acesso-Rede Interna
switchport access vlan 30
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
no ip address
interface FastEthernet5
no ip address
interface FastEthernet6
no ip address
interface FastEthernet7
no ip address
interface FastEthernet8
description Trunk-Rede Interna
switchport mode trunk
no ip address
interface Vlan1
no ip address
interface Vlan30
ip address 192.168.30.254 255.255.255.0
ip nat inside
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0
ip route 192.168.30.0 255.255.255.0 Vlan30 permanent
no ip http server
no ip http secure-server
ip nat inside source list ACL_de_Rede_Interna interface FastEthernet0 overload
ip access-list extended ACL_de_Rede_Interna
permit icmp any any echo-reply
permit ip 192.168.30.0 0.0.0.255 any
permit ip 192.168.173.0 0.0.0.255 any
deny   ip any any log
What is wrong?
António
Can you find some experienced or certified to configure your router?
For example a command like:
is a major mistake that a professional would have avoided.
Richard Burts
António
According to the information in this link it should work ok to use a FastEthernet as the WAN connection while using other interfaces/ports for local connectivity:
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/ps6184/product_data_sheet0900aecd8028a95f_ps5853_Products_Data_Sheet.html
Rick
Rick
António
You mention setting up a simple firewall. But all that I see is an access list controlling Address Translation. Perhaps you can clarify what you are trying to do.
My other question would be that if you can not access outside from the inside, can you access outside to the Internet from the router itself?
Perhaps you could post the output of show ip interface brief?
Rick
Rick
Hi Richard,
I am try to do a simple firewall, but want I real need is a firewall, IPS and VPN with this router.
But I started with one thing at the time. Firewall, IPS and next step will be the VPN.
My experience is with switching not with routers of this kind.
Thanks for any hell,
António
I cannot go out from the router, as You can see, with a simple ping.
router-fw#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 0 percent (0/5)
The show ip interfade brief is
router-fw#sh ip interface brief
ATM0 unassigned YES NVRAM administratively down down
BRI0 unassigned YES NVRAM administratively down down
BRI0:1 unassigned YES unset administratively down down
BRI0:2 unassigned YES unset administratively down down
FastEthernet0 192.168.173.137 YES DHCP up up
FastEthernet1 unassigned YES unset up up
FastEthernet2 unassigned YES unset up down
FastEthernet3 unassigned YES unset up down
FastEthernet4 unassigned YES unset up down
FastEthernet5 unassigned YES unset up down
FastEthernet6 unassigned YES unset up down
FastEthernet7 unassigned YES unset up down
FastEthernet8 unassigned YES unset up down
Vlan1 unassigned YES unset up down
Vlan30 192.168.30.254 YES NVRAM up up
Now I removed the line ip route 0.0.0.0 0.0.0.0 FastEthernet0 and I’m reach the internet from the router. But, the laptop or srv it is not possible. Because the laptop cannot solve the name www.cisco.com<> to IP address.
10x,
Hi guys,
After Paolo Bevilacqua sad “major mistake” when use ip route 0.0.0.0 0.0.0.0 FastEthernet0 I removed the line and them I removed ip route 192.168.30.0 255.255.255.0 Vlan30 permanent too. Now I can access to the Internet.
Then I try look for documents at the cisco and build a fews lines to the inspection.
Can anyone help me to find a good book to learn how to configure a firewall, active de IPS and configure the router to be a VPN?
Because some documents that are in the Internet don’t have the explanation why thing must doing this or that way
