Using Policy Based Routes to Restrict Nexthop
maxclark
Hi all,
I would like to set profiles on my router (6509 w/ Sup720 3BXL) to restrict outbound routes based on the source IP address. I.e. if I have three upstream providers (ISP A, B, and C) I would like to configure 10.0.0.0/24 to use ISP A and B but not C. Ideally this would be configured exclusionary (i.e. 10.0.0.0/24 not allowed via ISP C) vs. inclusionary.
All of the information that I have been able to find so far specifically Set's the next-hop (i.e. 10.0.0.0/24 next-hop equals ISP B), is there a way to do the reverse of this?
Thanks in advance,
Max
royalblues
Level 10
Level 10
Max,
Unfortunaltely when you do PBR for route selection you exclude the required subnet from the normal routing.
I dont think there's any reverse way possible.
But anyway the config should help you achieve what you want.
Narayan
Narayan,
Can you point me to the config example you mention.
Max
