Using Prefix-List for marching only one IP address
Hi all;
Suppose I receive routes with "10.149.42.0/24" prefix from adjacent router and I want to match exactly the "10.149.42.254" IP address, for filtering purpose. How can I match exactly this IP address using a prefix list?
Hello
Note:- The example below will ONLY filter from that router and NOT the ospf D?B
Example:
ip prefix-list HOST deny 10.149.42.254/32
ip prefix-list HOST permit 0.0.0.0/0 le 32
router ospf x
distribute-list prefix HOST  in
Kind Regards
Paul
5 Replies 5
Richard Burts
Can you clarify what kind of filtering purpose you are asking about? Is it filtering routing information about that host address or is it filtering traffic to or from that host address?
Rick
I want to use
 distribute-list
in OSPF to filter 10.149.42.254 address, so preventing it to insert in the routing table.
Are you receiving a route advertisement for that specific IP ?
It sounds from your description as you are only receiving the /24 so you can't then stop a specific IP from that range being inserted in the routing table.
Can you clarify ?
Jon
can you more elaborate ?
anyway this link for OSPF route filter
http://www.ccieordie.com/2-3-g-ospf-filtering
Hello
Example:
router ospf x
Kind Regards
Paul
