Downgrade IOS-XE 17.4.1 on Cisco 4431 to 16.6.x
johnlloyd_13
Level 9
Level 9
hi,
i'm configuring a 4431 with UC bundle and it's shipped with IOS-XE 17.4.1 by default.
i got an on-prem license server which uses smart call home and we're not ready yet for the newer CSLU transport/config in our 4K routers since we're still running 16.12.x code.
my question is, can i 'downgrade' my 4431 to 16.6.x code which our other voice router is currently running in order to register this to on-prem smart license server?
will it lose it's UC feature/license once i downgrade? or will it turn UC license to 'eval' then i have ask TAC to 'convert' or issue my UC license to a smart license?
smart license is such a pain and it delays our network deployment.
4431#show version
Cisco IOS XE Software, Version 17.04.01a
Cisco IOS Software [Bengaluru], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.4.1a, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Fri 18-Dec-20 05:04 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2020 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: (c)
4431 uptime is 3 hours, 55 minutes
Uptime for this control processor is 3 hours, 58 minutes
System returned to ROM by PowerOn
System image file is "bootflash:isr4400-universalk9.17.04.01a.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite                 Suite Current         Type           Suite Next reboot
FoundationSuiteK9     None                  Smart License  None
securityk9
appxk9
AdvUCSuiteK9          None                  Smart License  None
uck9
cme-srst
cube
Technology Package License Information:
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
appxk9           None             Smart License    None
uck9             uck9             Smart License    uck9
securityk9       None             Smart License    None
ipbase           ipbasek9         Smart License    ipbasek9
The current throughput level is 500000 kbps
Smart Licensing Status: Registration Not Applicable/Not Applicable
4431#sh license summ
License Usage:
  License                 Entitlement Tag               Count Status
  uck9                    (ISR_4400_UnifiedCommun...)       1 IN USE
4431#sh license status
Utility:
  Status: DISABLED
Smart Licensing Using Policy:
  Status: ENABLED
Data Privacy:
  Sending Hostname: yes
    Callhome hostname privacy: DISABLED
    Smart Licensing hostname privacy: DISABLED
  Version privacy: DISABLED
Transport:
  Type: cslu
  Cslu address: <empty>
  Proxy:
    Not Configured
Policy:
  Policy in use: Merged from multiple sources.
  Reporting ACK required: yes (CISCO default)
  Unenforced/Non-Export Perpetual Attributes:
    First report requirement (days): 365 (CISCO default)
    Reporting frequency (days): 0 (CISCO default)
    Report on change (days): 90 (CISCO default)
  Unenforced/Non-Export Subscription Attributes:
    First report requirement (days): 90 (CISCO default)
    Reporting frequency (days): 90 (CISCO default)
  Enforced (Perpetual/Subscription) License Attributes:
    First report requirement (days): 0 (CISCO default)
    Report on change (days): 0 (CISCO default)
  Export (Perpetual/Subscription) License Attributes:
Miscellaneous:
  Custom Id: <empty>
Usage Reporting:
  Last ACK received: <none>
  Next ACK deadline: May 18 13:42:16 2023 UTC
  Reporting push interval: 30  days
  Next ACK push check: <none>
  Next report push: May 18 13:44:16 2022 UTC
  Last report push: <none>
  Last report file write: <none>
Trust Code Installed: <none>
8 Replies 8
balaji.bandi
You can downgrade, but smart License need to convert to old traditional, you need to get involve License or TAC for that.
instead, i would advice to uplift to version of code  where smart License accepted both devices.
BB
johnlloyd_13
Level 9
Level 9
hi balaji,
thanks for your feedback! that's what i suspect when i downgrade and need to involve TAC.
what do you mean uplift code? can you expound please.
as you can see here 17.4.x started using CSLU and our on-prem is not ready for it yet. we're still using 'smart' or call-home in our 4K routers.
Since you mentioned you already running OLD Code in the premises, so why not use new Kit with latest version ( you can use this approtuntiy) build new code and test it, and do cut over. and make upgrade old 1.6.6 to latest code. (i mean of uplift this version, before TAC anounce end of Life, may be they did).
https://community.cisco.com/t5/cisco-software-documents/smart-license-using-policy-slp/ta-p/4167670
BB
Leo Laohoo
Heeeeeeeeeeeeeeey, WTF!
Can I see the first seven characters of the serial number of the chassis?
Cisco said all routers, switches and WLC manufactured after February 2022 will now be in Install Mode.
hi leo,
FCZ2615
where did you read that? link?
as you can see there's no 'install' mode in the 'show version' output.
FCZ2615
Date of Manufacture is some time 3rd week of April 2022.  So this is new.
Ok, now you've jarred my memory.
All Catalyst 8k router shipped with 17.7.X will ship in "Install Mode".
What’s New? IOS XE 17.7 Routing Release​ Update
Ship in "install mode" instead of "bundle mode"
In previous releases, images were installed using a .bin file. The router would go through various images before locating the correct one for that device and then boot up. Also, when inserting a new module or chassis, manual intervention was required to get the new switch running on the same version as active switches or modules.
Enhancements Starting with 17.7        With the 17.7 release, Catalyst 8200, 8300, 8500, and 8500L will ship in 'install mode,' which enables a faster boot time, image auto-upgrade, increased flexibility, and improved performance.
johnlloyd_13
Level 9
Level 9
you're out of topic here.
per subject, this is about 4K ISR and smart license.
Well, start with the basic.  Is the serial number of the router in the correct Service Contract.
If it is, contact the License Team and ask them to send a PAK with UC enabled.
Only then do you downgrade the firmware of the router.
