Cisco Router Site-to-Site IPsec - Routing (fallback)
yh-it
I want to use a direct connection between to routers as "first" way for the traffic and as fallback I want to route the traffic to VPN.
The setup is / shoud use bfd for static routes.
But I am not able to route the traffic trough the VPN. So where is my mistake?
R1:
crypto isakmp policy 1
 encr 3des
 hash md5
 authentication pre-share
 group 2
crypto isakmp key xxxxxxxxxxxxx address xxxxxxxxxxxxxxx
crypto ipsec transform-set TS esp-3des esp-md5-hmac
 mode tunnel
crypto map CMAP 10 ipsec-isakmp
 set peer xxxxxxxxxxxxxxxxxxxxxxx
 set transform-set TS
 match address VPN-TRAFFIC
interface Loopback0
 ip address 179.31.4.49 255.255.255.240
interface Loopback1
 ip address 10.0.0.1 255.255.255.0
interface GigabitEthernet0/0/0
 description Uplink Richtfunkstrecke
 ip address 179.31.4.17 255.255.255.240
 negotiation auto
 bfd interval 500 min_rx 500 multiplier 5
interface GigabitEthernet0/0/1
 no ip address
 negotiation auto
interface GigabitEthernet0/1/0
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface GigabitEthernet0/1/4
interface GigabitEthernet0/1/5
interface GigabitEthernet0/1/6
interface GigabitEthernet0/1/7
interface Vlan1
 description Uplink Firewall
 ip address 179.31.4.2 255.255.255.240
 crypto map CMAP
interface Vlan2
 no ip address
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 100 interface Vlan1 overload
ip route static bfd GigabitEthernet0/0/0 179.31.4.18 group group1
ip route 0.0.0.0 0.0.0.0 179.31.4.1
ip route 10.0.1.1 255.255.255.255 GigabitEthernet0/0/0 179.31.4.18
ip route 10.1.1.1 255.255.255.255 GigabitEthernet0/0/0 179.31.4.18
ip route 10.32.1.0 255.255.255.0 179.31.4.1
ip route 10.32.10.0 255.255.254.0 179.31.4.1
ip route 10.32.22.0 255.255.255.0 179.31.4.1
ip route 10.112.80.0 255.255.255.0 Loopback0 179.31.4.65 20
ip route 179.23.12.0 255.255.255.0 179.31.4.1
ip route 179.31.4.32 255.255.255.240 GigabitEthernet0/0/0 179.31.4.18
ip route 192.168.50.0 255.255.255.0 179.31.4.1
ip ssh version 2
ip access-list extended VPN-TRAFFIC
 permit ip 179.31.4.48 0.0.0.15 179.31.4.64 0.0.0.15
 permit ip 179.31.4.0 0.0.0.15 179.31.4.64 0.0.0.15
access-list 100 remark -=[Define NAT Service]=-
access-list 100 deny   ip 179.31.4.48 0.0.0.15 179.31.4.64 0.0.0.15
access-list 100 permit ip 179.31.4.48 0.0.0.15 any
R2:
 encr 3des
 hash md5
 group 2
crypto isakmp key xxxxxxxxx address xxxxxxxxxxx
 mode tunnel
interface Loopback0
 ip address 179.31.4.65 255.255.255.240
interface Loopback2
 ip address 10.0.1.1 255.255.255.0
 ip address 179.31.4.18 255.255.255.240
 negotiation auto
 no ip address
 negotiation auto
interface Vlan1
 ip address 179.31.4.34 255.255.255.240
 crypto map CMAP
interface Vlan2
 no ip address
ip http server
ip route static bfd GigabitEthernet0/0/0 179.31.4.17 group group1
ip route 0.0.0.0 0.0.0.0 179.31.4.33
ip route 10.0.0.1 255.255.255.255 GigabitEthernet0/0/0 179.31.4.17
ip route 10.32.1.0 255.255.255.0 Loopback0 179.31.4.49 20
ip route 10.32.10.0 255.255.254.0 GigabitEthernet0/0/0 179.31.4.17
ip route 10.32.22.0 255.255.255.0 GigabitEthernet0/0/0 179.31.4.17
ip route 10.112.80.0 255.255.255.0 179.31.4.33
ip route 179.23.12.0 255.255.255.0 GigabitEthernet0/0/0 179.31.4.17
ip route 179.31.4.0 255.255.255.240 GigabitEthernet0/0/0 179.31.4.17
ip route 192.168.50.0 255.255.255.0 GigabitEthernet0/0/0 179.31.4.17
 permit ip 179.31.4.64 0.0.0.15 179.31.4.48 0.0.0.15
 permit ip 179.31.4.0 0.0.0.15 179.31.4.0 0.0.0.15
access-list 100 deny   ip 179.31.4.64 0.0.0.15 179.31.4.48 0.0.0.15
access-list 100 permit ip 179.31.4.64 0.0.0.15 any
at first glance, the NAT access lists do not look correct. Make sure you deny (on both sides) exactly what is allowed in the VPN access list. The NAT access lists should look like this:
R1
access-list 100 deny ip 179.31.4.0 0.0.0.15 179.31.4.64 0.0.0.15
R2
access-list 100 deny ip 179.31.4.0 0.0.0.15 179.31.4.0 0.0.0.15
I think you should use a routing protocol for this and not try to it all with static routes. The main reason for this is that if you lose connectivity over the direct G0/0 interface but the interface doesn't physically go down, you will not fail over to the VPN path. If you run a routing protocol and have a floating static (less preferred admin distance) to the VPN path, that will fail over even if G0/0 is is up when the connectivity is lost.
