v.35 8 port card compability
princekochva
I have a v.35 card (8 ports) it is located inside my 7500, i would like to
put it inside my 7200 router , which command will tell me if it is compatible .
spremkumar
Level 9
Level 9
can u give a show diag command in your 7500 box and find out the exact description or the model name of the card being installed already in the box ?
with that we can find out whether we can insert the same card in the vxr routers and also the compatability of the card in the 7200 series router..
regds
