V-LAN ROUTING ISSUE ???
afzaal.qadir
GOOOODMorning
I am facing an issue that i have a network in 5 building with different V-LANs, The problem is that they are not communiating on WAN. for example i want ping buildind A PC of Same Vlan from building B they not respomding.
Plz find the Attcahed Config files of building A & building B routers you will understand better..
thanks n regards
16 Replies 16
Mohamed Sobair
Level 7
Level 7
Afzaal,
First you need to check the following:
RouterA:
ip address 192.168.4.126 255.255.255.0
network 192.168.4.0 0.0.0.127
Although the Network statment is part of the interface Network, but to be precise you may correct it as follows:
IP address 192.168.4.126 255.255.255.128
RouterB:
ip address 192.168.4.254 255.255.255.0
network 192.168.4.128 0.0.0.127
Although the Network statment is part of the Network interface, but to be precise you may correct it to the following:
ip address 192.168.4.254 255.255.255.128
Second:
You need to disable (auto-summary), eithout disabling auto-summary, Eigrp Summarize the Network to its classfull Network at majour Network boundaries, so the routing table wont have the more Specific route for each Network.
The routing table in R1 will have the following Network:
192.168.2.0
192.168.3.0
192.168.4.0
Those Networks are being summarized due to the Auto-summary command. The correct solution is to disable auto-summary with (no auto-summary).
Mohamed
don-sullivan
This post are the switches.
