Very difficult issue to solve with RV042
douglas.nandi
Hi.
In my company we have one RV042 used to switch to WANs. When WAN1 fail, the WAN2 assumes.
In resume:
All is ok until here. But both WAN1 and WAN2 are LANs that have an specific range in IP address and one getaway each to the internet. The problem is: I want to access the LAN of WAN1 even when I use the WAN2 internet.
Detailed:
A - RV042 - Network 192.168.1.XXX (IP:192.168.1.1)
Smart Link Backup
Primary WAN: WAN1
Enable Network Service Detection: TRUE
When Fail: REMOVE THE CONNECTION
X - Router on WAN1 - Network 172.30.1.XXX (IP:172.30.1.1)
(I can't access this network when I use the WAN2, but I need)
Y - Router on WAN2 - Network 172.30.3.XXX (IP:172.30.3.1)
(I can't access this network when I use the WAN1, but I need)
Thanks for help.
syed.raza
its better if you can share a diagram of the setup. Just a quick concern: why dont you have routing between the two WANs. all you need is a router with legs in each WAN and the correct routing.
share a diagram to better understand the situation.
Syed
Thanks for helping Syed!! The problem is: I don't want to use the load balance, I want to use only one WAN at a time. When the WAN1 fail, the WAN2 assumes and I loss the connection with the LAN 172.30.1.XXX. And vice-versa.
Dear,
Is this not exactly what you have configured on RV042
Smart Link Backup
Primary WAN: WAN1
The above line says if WAN1 and WAN2 are avaiable WAN1 is active..................rite?
when WAN1 fails, remove WAN1 ( which is a subnet) so u cannot communicate with WAN1.
since WAN1 has failed WAN2 became active so you can communicate with it.
IS THAT CORRECT?
what if i say you remove everything from your RV042 and simply connect 3 subnets wan1, wan2 and the 192.168.x.x subnet. i am sure you problem will go away. u wll be able to communicate to all 3 rgadless of which wan has failed.
the logic for primary and backup wan links should be in the default routes towards each internet connection.
let say you have 2 default routes to the internet
route 1 : 0.0.0.0 0.0.0.0. via wan link 1 priority 100
route 2: 0.0.0.0 0.0.0.0 via wan link 2 priority 200
if you have the above in the RV042 what will happen that wan link1 will be primary; if it fails wan link 2 will start working. when wan link 1 resumes it will again become primary and wan link 2 will become secondary.
hope this helps.
syed
