VIC3-4FXS/DID
Dear,
I have CUCM 7 installed on Cisco 3825 ISR Router at presently we don't have PSTN termination on it, I want to install and configure the PSTN termination. we have VIC3-4FXS/DID card, On Cisco 3825 router IOS is (Cisco IOS Software, 3800 Software (C3825-ADVIPSERVICESK9-M), Version 12.4(24)T3,
 RELEASE SOFTWARE (fc2)  | (Cisco IOS Software, 3800 Software (C3825-ADVIPSERVICESK9-M), Version 12.4(24)T3,
 RELEASE SOFTWARE (fc2) Kindly assit me to do the PSTN termination.
11 Replies 11
acampbell
Using a FXS/DID for PSTN I think you will be struggling
trying to buy/rent a DID trunk from a TELCO nowadays.
The FXS element is for connecting to actual analogue phones
NOT lines.
You would be better to investigate finding/buying an FXO card if you need to use
POTS PSTN or is ISDN BRI/PRI option... SIP trunking is now abundant with most TELCOs
for a modern solution.
Alex
Regards, Alex. Please rate useful posts.
Thanks Alex for your assistance,
I am going to configure outgoing call from CUCM 7.1 , and I have two cards connected on the mentioned above router Cisco 3800 Series FXS and FXO both the cards I already connected, But the card interface LED'S are in Amber color , what I need to know is the interface card is supported for the above IOS and Cisco Router.
Hi Mohamed,
Does your router have a relevant DSP (PVDM) module installed, you need this for analogue or digital telephony signal conversion to IP.
show diag will let you see what is installed.
Alex
Hi Alex
the below is the details
CME#show ver
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 23-Mar-10 10:35 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
CME uptime is 2 days, 1 hour, 57 minutes
System restarted at 13:15:56 SA Tue Jul 21 2015
System image file is "flash:c3825-advipservicesk9-mz.124-24.T3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found a
export@cisco.com.
Cisco 3825 (revision 1.2) with 479231K/45056K bytes of memory.
Processor board ID FCZ141371J0
2 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
4 Voice FXS interfaces
1 cisco Integrated Service Engine(s)
   Cisco Unity Express 7.0.5 in slot 1
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
255232K bytes of ATA System CompactFlash (Read/Write)
Hi Mohamed,
Can you share
show inv
show diag
Alex
Hi Alex,
find below
CME#show inventory
NAME: "3825 chassis", DESCR: "3825 chassis"
PID: CISCO3825         , VID: V05 , SN: FCZ141371J0
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSl
ot 2", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO         , VID: V04 , SN: FOC160249PS
NAME: "3rd generation four port FXS DID voice interface daughtercard on Slot 0 S
ubSlot 3", DESCR: "3rd generation four port FXS DID voice interface daughtercard
PID: VIC3-4FXS/DID     , VID: V03 , SN: FOC18095ZPB
NAME: "Integrated Service Engine for Modular and Integrated Services Routers on
Slot 1", DESCR: "Integrated Service Engine for Modular and Integrated Services R
outers"
PID: NME-CUE           , VID: V01 , SN: FOC133818CP
Show Diag
CME#show dia?
diag  dial-peer  dialer  dialplan
CME#show diag
Slot 0:
        C3825 Mother board 1GE(TX,SFP),1GE(TX), integrated VPN and 4W Port adapt
er, 10 ports
        Port adapter is analyzed
        Port adapter insertion time 2d02h ago
        Onboard VPN             : FW ver01100200
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC14114NL4
        Hardware Revision        : 1.2
        Top Assy. Part Number    : 800-23087-05
        Board Revision           : C0
        Deviation Number         : 102138
        Fab Version              : 07
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Processor type           : 61
        Hardware date code       : 20100316
        Chassis Serial Number    : FCZ141371J0
        Chassis MAC Address      : 0026.999d.9530
        MAC Address block size   : 32
        CLEI Code                : IPMKX00ARA
        Product (FRU) Number     : CISCO3825
        Part Number              : 73-4021-10
        Version Identifier       : V05
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 34 31 31 34 4E 4C 34 40
          0x10: 04 2A 41 01 02 C0 46 03 20 00 5A 2F 05 42 43 30
          0x20: 88 00 01 8E FA 02 07 03 00 81 00 00 00 00 04 00
          0x30: 09 61 83 01 32 B4 DC C2 8B 46 43 5A 31 34 31 33
          0x40: 37 31 4A 30 C3 06 00 26 99 9D 95 30 43 00 20 C6
          0x50: 8A 49 50 4D 4B 58 30 30 41 52 41 CB 89 43 49 53
          0x60: 43 4F 33 38 32 35 82 49 0F B5 0A 89 56 30 35 20
          0x70: D9 03 40 C1 C2 FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 2:
        2nd generation - FXO Voice daughter card (4 port)
        Hardware Revision        : 5.0
        Top Assy. Part Number    : 800-33585-01
        Board Revision           : D0
        Deviation Number         : 0-0
        Fab Version              : 04
        PCB Serial Number        : FOC160249PS
        RMA History              : 00
        Product (FRU) Number     : VIC2-4FXO
        Version Identifier       : V04
        CLEI Code                : CNUIAXJAAC
          0x00: 04 FF 40 00 4C 41 05 00 C0 46 03 20 00 83 31 01
          0x10: 42 44 30 80 00 00 00 00 02 04 C1 8B 46 4F 43 31
          0x20: 36 30 32 34 39 50 53 03 00 81 00 00 00 00 04 00
          0x30: CB 89 56 49 43 32 2D 34 46 58 4F 89 56 30 34 20
          0x40: C6 8A 43 4E 55 49 41 58 4A 41 41 43 FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 3:
        3rd generation - FXS DID Voice daughter card (4 port)
        Hardware Revision        : 1.0
        Top Assy. Part Number    : 800-33583-01
        Board Revision           : E0
        Fab Version              : 07
        PCB Serial Number        : FOC18095ZPB
        RMA History              : 00
        Product (FRU) Number     : VIC3-4FXS/DID
        Version Identifier       : V03
        CLEI Code                : IPUIA6JRAC
        Longitudinal Calibration : 01 10 10 81 8C 10 10 85
                                   A5 10 10 74 5B 10 10 98
                                   69
          0x00: 04 FF 40 05 1B 41 01 00 C0 46 03 20 00 83 2F 01
          0x10: 42 45 30 88 00 00 00 00 02 07 C1 8B 46 4F 43 31
          0x20: 38 30 39 35 5A 50 42 03 00 81 00 00 00 00 04 00
          0x30: CB 8D 56 49 43 33 2D 34 46 58 53 2F 44 49 44 89
          0x40: 56 30 33 20 D9 02 40 C1 C6 8A 49 50 55 49 41 36
          0x50: 4A 52 41 43 D3 11 01 10 10 81 8C 10 10 85 A5 10
          0x60: 10 74 5B 10 10 98 69 FF FF FF FF FF FF FF FF FF
Slot 1:
        Integrated Service Engine Port adapter, 1 port
        Part Number              : 73-10371-03
        Top Assy. Part Number    : 800-29801-01
        Board Revision           : B0
        Deviation Number         : 104263
        Fab Version              : 01
        PCB Serial Number        : FOC133818CP
        RMA History              : 00
        Product (FRU) Number     : NME-CUE
        Version Identifier       : V01
        CLEI Code                : IPUIA6NRAA
          0x00: 04 FF 40 04 F8 41 01 00 82 49 28 83 03 C0 46 03
          0x10: 20 00 74 69 01 42 42 30 88 00 01 97 47 02 01 C1
          0x20: 8B 46 4F 43 31 33 33 38 31 38 43 50 03 00 81 00
          0x30: 00 00 00 04 00 CB 87 4E 4D 45 2D 43 55 45 89 56
          0x40: 30 31 20 D9 03 40 C1 CB C6 8A 49 50 55 49 41 36
          0x50: 4E 52 41 41 FF FF FF FF FF FF FF FF FF FF FF FF
         - Integrated Service Engine Daughter Card.
        Part Number              : 73-10372-01
        Top Assy. Part Number    : 800-29814-01
        Board Revision           : A0
        Deviation Number         : 104754
        Fab Version              : 01
        PCB Serial Number        : FOC133819RL
        RMA History              : 00
          0x00: 04 FF 40 04 F9 41 01 00 82 49 28 84 01 C0 46 03
          0x10: 20 00 74 76 01 42 41 30 88 00 01 99 32 02 01 C1
          0x20: 8B 46 4F 43 31 33 33 38 31 39 52 4C 03 00 81 00
          0x30: 00 00 00 04 00 D9 02 40 C1 FF FF FF FF FF FF FF
          0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Mohamed,
You can see yourself from show inv that there NO DSP (PVDM) chips fitted in your router.
You will need to source a PVDM in order to run any FXO,FXS,PRI or BRI cards.
Alex
Hi Alex,
Thank you very much for your assistence.
i am very new for CUCM Config and PSTN termination. i will ask to buy PVDM Chip to my company. can you suggest me which one i want buy Like below
PVDM2-8, PVDM2-16, PVDM2-32, PVDM2-48, and PVDM2-64
Mohamed
Mohamed,
If costs are important then a PVDM2-8 will be OK -- But you will have no room for any expansion or to use your router for CUCM MTP/trancoding resources.
If money is OK - I suggest you go for the PVDM2-64 as you could add more FXS ports for example and also use the DSP for smoe transcoding resources.
If you have a CCO account then have a look at the DSP calculator tool on
http://www.cisco.com/web/applicat/dsprecal/dsp_calc.html
I hope this helps
Alex
Hi Alex ,
Sorry for the delay,
Thanks for your assistance and reply , I will get the PVDM then I will configure PSTN termination if any assistance require I will ask you
Mohamed
ask your provider sip trunk instead lines
