View internal IP routes
jwbensley
Is there anyway I can see how many routes are internal to an AS?
So, something like "show ip route in AS1234" where AS1234 is the local AS number. All internal routes within AS1234 are being parsed around via iBGP, but AS1234 has a full BGP table from upstream provides so "show ip route" shows all local and global routes. How can I see all the routes within the local AS only?
Many thanks!
rais
Level 7
Level 7
You can try:
     show ip bgp regexp ^$
HTH.
rais
Level 7
Level 7
You can try:
HTH.
Perfect, thanks!
