vlan.dat message problem
enfelak101
Hello dears,
I have 2 IOS loaded into the flash on a Cisco 2960 plus switch
the first IOS is the default that was loaded from the factory and the other was loaded by me
every thing goes fine when i boot the default IOS ,but when i tried the other one that i loaded ,i have the following message
%SW_VLAN-4-IFS_FAILURE: VLAN manager encountered file operation error: call = ifs_open/read / file = flash:/vlan.dat / code = 19 (No such device) / bytes transfered = 0
i tried to delete vlan.dat from flash and i could not ,as in the normal enable mode ,the switch can not recognize the (show flash) command
http://imgur.com/WVRwWY2
so i had to delete the file from the ROMMON mode usin (Flash_init & Dir flash & Delete Flash:vlan.dat) commands
when i return to the normal modes and boot the IOS ,I find that same message appears and the switch is forced to be in the client VTP mode
I tried to make it as VTP server but as soon as i write the command ,the same message appears and no change
any one has a solution ?
7 Replies 7
Mark Malone
in normal mode did you try dir flash: when in normal mode rather than show flash , aswell even if you cant see t try delete flash:vlan.dat
looks like a bug in some platforms when you check that error , no good workarounds though in them , its definite corruption of the file though
did you try create new vlans too on the ios you want and save ad see if it overwrites the vlan.dat file
I have tried all what you have said
also as i wrote the switch is in the client vtp mode and i can not change it
now i am trying a new IOS
maybe the IOS has a problem
yes i would do the same at this stage force delete the base ios out of with the  switch delete /force /recursive flash:........  and then let it boot the new one just make sure its verified with md5 so its not corrupt and doesn't put you in rmon
a.alekseev
Level 7
Level 7
With "default IOS" could you show the outputs
sh ver
dir flash:
yeah I can do that
but i need to configure IP SLA on the switch and the SLA commands are not available on the default IOS so i need to change the IOS
show the outputs
sh ver
dir flash:
enfelak101
Till now I have tried many IOS versions and with the same problem
Do any one has more suggestions
