vlan ovr access point not working
roncro
Level 3
Level 3
I didn't really want to re-post this..  but I am kind of stuck.  I have several access points that handle different VLANs, for different equipment, to keep them separated.  On the  router and switch I basically copied and edited the entries for a new vlan (vlan 9) and configured an ap for it, set up like the others,  but for the new vlan 9.  But no traffic tcp/dhcp seems to  "go through". I have the configs for the router I have (a Cisco 2951), a switch the access point is connected to (a Cisco 2960) and an access point (an aironet 1100)
Here are the configs.  (All the other vlans over APs work,  so I am kinda pulling my hair out,  why this new vlan 9 is not working.)
(I don't think any traffic is going through the AP from clients, but they get "associated".  I don't see any DHCP messages from that subnet (192.168.9.0), the other wireless networks just work fine.
thank you!.
the Aironet 1100 AP:
ap-nata#show run
Building configuration...
Current configuration : 2087 bytes
! No configuration change since last restart
version 12.3
no service pad
service password-encryption
hostname ap-nata
no logging console
clock timezone -0700 -7
clock summer-time -0600 recurring
ip subnet-zero
no ip domain lookup
ip domain name localdomain
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
dot11 ssid TM-NATA
vlan 9
authentication open
guest-mode
dot11 network-map
username admin privilege 15 password 7 105A1A0C0B161F025D57
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid TM-NATA
speed 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.9
encapsulation dot1Q 9
no ip route-cache
bridge-group 9
bridge-group 9 subscriber-loop-control
bridge-group 9 block-unknown-source
no bridge-group 9 source-learning
no bridge-group 9 unicast-flooding
bridge-group 9 spanning-disabled
interface Dot11Radio0.37
encapsulation dot1Q 37 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.9
no ip route-cache
bridge-group 9
interface FastEthernet0.37
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.37.22 255.255.255.0
no ip route-cache
ip default-gateway 192.168.37.1
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
sntp server 192.168.1.1
sntp broadcast client
end
the Cisco 2951 router:
Charon-2951#show run
Current configuration : 11091 bytes
! Last configuration change at 22:13:50 MST Wed Jan 24 2024 by admin
! NVRAM config last updated at 15:01:13 MST Wed Jan 17 2024 by admin
version 15.6
hostname Charon-2951
boot-start-marker
boot system flash0:c2951-universalk9-mz.SPA.156-3.M9.bin
boot system flash0:c2951-universalk9-mz.SPA.154-1.T1.bin
boot-end-marker
enable secret 5 $1$Y6Ap$foIYqVqbcci.b9/iOKKVt/
no aaa new-model
clock timezone MST -7 0
clock summer-time MDT recurring
no ip source-route
no ip dhcp conflict logging
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp excluded-address 192.168.2.1 192.168.2.10
ip dhcp excluded-address 192.168.4.1 192.168.4.10
ip dhcp excluded-address 192.168.5.1 192.168.5.10
ip dhcp excluded-address 192.168.6.1 192.168.6.10
ip dhcp excluded-address 192.168.7.1 192.168.7.10
ip dhcp excluded-address 192.168.3.1 192.168.3.10
ip dhcp excluded-address 192.168.8.1 192.168.8.10
ip dhcp excluded-address 192.168.9.1 192.168.9.10
ip dhcp ping timeout 600
ip dhcp pool VLAN1-POOL
import all
origin file tftp://192.168.2.8/dhcp/static-bindings-hw-1
default-router 192.168.1.1
dns-server 192.168.1.1
domain-name localdomain
option 42 ip 192.168.1.1
ip dhcp pool VLAN4-DCH-S150
import all
origin file tftp://192.168.2.8/dhcp/static-bindings-hw-4
default-router 192.168.4.1
ip dhcp pool VLAN6-TONTON-POOL
import all
origin file tftp://192.168.2.8/dhcp/static-bindings-hw-6
default-router 192.168.6.1
ip dhcp pool VLAN2-SERVERS
import all
origin file tftp://192.168.2.8/dhcp/static-bindings-hw-2
default-router 192.168.2.1
ip dhcp pool VLAN3-DEVICES-POOL
import all
origin file tftp://192.168.2.8/dhcp/static-bindings-hw-3
default-router 192.168.3.1
ip dhcp pool VLAN7-THE-MATRIX-POOL
import all
origin file tftp://192.168.2.8/dhcp/static-bindings-hw-7
default-router 192.168.7.1
ip dhcp pool VLAN5-WEMO-POOL
import all
origin file tftp://192.168.2.8/dhcp/static-bindings-hw-5
default-router 192.168.5.1
ip dhcp pool VLAN8-SEISMO
import all
origin file tftp://192.168.2.8/dhcp/static-bindings-hw-8
default-router 192.168.8.1
ip dhcp pool VLAN9-NATA-EQUIPMENT-POOL
import all
origin file tftp://192.168.2.8/dhcp/static-bindings-hw-9
default-router 192.168.9.1
ip host cisco-ap1.localdomain 192.168.37.11
ip host cisco-ap-seismo.localdomain 192.168.37.20
ip host cisco-ap-nata.localdomain 192.168.37.22
ip host cisco-ap2.localdomain 192.168.37.12
ip host charon.localdomain 192.168.1.1
ip host C2960s-south.localdomain 192.168.1.3
ip host zoneminder.localdomain 192.168.2.8
ip host trotter.localdomain 192.168.1.112
ip host f007th.localdomain 192.168.3.163
ip host wemo.localdomain 192.168.7.37
ip host seismo.localdomain 192.168.8.84
ip host cisco-ap9.localdomain 192.168.37.19
ip host cisco-ap6.localdomain 192.168.37.16
ip host trotter67.localdomain 192.168.1.109
ip host cnc.localdomain 192.168.2.115
ip host cuda.localdomain 192.168.2.116
ip host zonemaster.localdomain 192.168.1.116
ip host picoscope.localdomain 192.168.2.37
ip host C2960s-north.localdomain 192.168.1.2
ip host AP-TM-W-F7C033.localdomain 192.168.1.5
ip host trotter68.localdomain 192.168.1.110
ip host trotter68.central-plex.us 192.168.1.113
ip host waves.localdomain 192.168.2.118
ip host quadra.localdomain 192.168.7.38
ip host Samsung-HDTV.localdomain 192.168.3.3
ip host wintrotter.localdomain 192.168.1.106
ip host picopod.localdomain 192.168.1.107
ip host cisco-ap7.localdomain 192.168.37.17
ip host cisco-ap8.localdomain 192.168.37.18
ip host north.localdomain 192.168.1.2
ip host cisco-ap5.localdomain 192.168.37.15
ip host south.localdomain 192.168.1.3
ip host cisco-ap-seismo-2.localdomain 192.168.37.21
ip name-server 8.8.8.8
ip name-server 9.9.9.9
ip cef
no ipv6 cef
crypto pki trustpoint TP-self-signed-2518389273
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2518389273
revocation-check none
rsakeypair TP-self-signed-2518389273
crypto pki certificate chain TP-self-signed-2518389273
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32353138 33383932 3733301E 170D3233 31303137 31353039
33315A17 0D333030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 35313833
38393237 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100AA4A 8AFE69E1 98501862 7CCDAC68 CF920A38 CEFE59A5 B42C9882 B6C2ED51
4E56AC77 1B0E8416 C3D8C7F6 44812076 3D60D3D8 21A51EBD 60B61AB8 42273954
647E3D30 3FD79800 CED4F138 24981F5E C633D623 D1431B16 CDCCAB6F A966AA95
E627D4E4 65203C54 D69D4E5A ABAB2A8F 8EDC3EEA CA0EFA32 433C2C19 8B5E777E
A87B0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 140F4538 3AD46471 F15FCA02 2AFDC119 8529B18D 82301D06
03551D0E 04160414 0F45383A D46471F1 5FCA022A FDC11985 29B18D82 300D0609
2A864886 F70D0101 05050003 81810002 303BAC26 A9A0A9B6 CC3707FD 5931A7B0
3008CCE3 F5AB7FFB 588A6A62 DBAB6B3F 4B2D9621 82B19848 04518953 E82BC639
50317FB7 49425CB9 41EA5C2B 313BC190 73FC17D0 A8A48FC7 1E64DEF9 A610EA5B
20B05AF5 0976B3D7 45203D4B D1C46B6C 717B6CF1 B635F0D3 28B39B21 2158662C
CCD1D521 766CCCCE 08140223 B9651B
quit
voice-card 0
vxml logging-tag
license udi pid CISCO2951/K9 sn FCZ1622702R
hw-module pvdm 0/0
hw-module pvdm 0/1
username admin privilege 15 password 7 1500085A550A3F373D3D342F1A5441
redundancy
buffers huge size 49152
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description WAN
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description LAN
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.1
encapsulation dot1Q 1 native
ip helper-address 192.168.2.255
ip nat inside
interface GigabitEthernet0/1.2
encapsulation dot1Q 2
ip address 192.168.2.1 255.255.255.0
ip helper-address 192.168.1.1
ip directed-broadcast
ip nat inside
interface GigabitEthernet0/1.3
ip address 192.168.3.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.4
encapsulation dot1Q 4
ip address 192.168.4.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.5
encapsulation dot1Q 5
ip address 192.168.5.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.6
encapsulation dot1Q 6
ip address 192.168.6.1 255.255.255.0
interface GigabitEthernet0/1.7
encapsulation dot1Q 7
ip address 192.168.7.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.8
encapsulation dot1Q 8
ip address 192.168.8.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.9
ip address 192.168.9.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.37
ip address 192.168.37.1 255.255.255.0
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip forward-protocol udp discard
ip http server
ip http authentication local
ip dns view default
domain list localdomain
ip dns server
ip nat inside source list 101 interface GigabitEthernet0/0 overload
ip nat inside source list 102 interface GigabitEthernet0/0 overload
ip nat inside source list 103 interface GigabitEthernet0/0 overload
ip nat inside source list 104 interface GigabitEthernet0/0 overload
ip nat inside source list 105 interface GigabitEthernet0/0 overload
ip nat inside source list 107 interface GigabitEthernet0/0 overload
ip nat inside source list 108 interface GigabitEthernet0/0 overload
ip nat inside source static tcp 192.168.2.8 22 interface GigabitEthernet0/0 22
ip nat inside source static tcp 192.168.2.8 80 interface GigabitEthernet0/0 80
ip nat inside source list 109 interface GigabitEthernet0/0 overload
ip nat inside source list 167 interface GigabitEthernet0/0 overload
ip nat inside source list 168 interface GigabitEthernet0/0 overload
ip route 192.168.66.0 255.255.255.0 192.168.1.112
ip route 192.168.67.0 255.255.255.0 192.168.1.112
ip route 192.168.68.0 255.255.255.0 192.168.1.116
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
ip ssh version 2
nls resp-timeout 1
cpd cr-id 1
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 102 permit ip 192.168.2.0 0.0.0.255 any
access-list 103 permit ip host 192.168.3.164 any
access-list 104 permit ip host 192.168.4.237 any
access-list 105 permit ip host 192.168.5.237 any
access-list 107 permit ip 192.168.7.0 0.0.0.255 any
access-list 108 permit ip 192.168.8.0 0.0.0.255 any
access-list 109 permit ip 192.168.9.0 0.0.0.255 any
access-list 163 permit ip 192.168.3.0 0.0.0.255 any
access-list 167 permit ip 192.168.67.0 0.0.0.255 any
access-list 168 permit ip 192.168.68.0 0.0.0.255 any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
gatekeeper
shutdown
line con 0
transport preferred none
line aux 0
line 2
no activation-character
no exec
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password 7 105C0A4F54370618190A2B262D7B64
login local
transport input ssh
line vty 5 15
login local
transport input ssh
scheduler allocate 20000 1000
ntp master
ntp update-calendar
ntp server time.nist.gov
end
the Cisco 2960 switch:
South#show run
Current configuration : 5843 bytes
version 12.2
no service pad
no service dhcp
hostname South
boot-start-marker
boot-end-marker
enable secret 5 $1$S873$6ik6XiM5OMHyd3u/oKuOc/
username admin password 7 05190559706C5A1A0C0B161F025F53
no aaa new-model
clock timezone UTC -7
clock summer-time UTC recurring
switch 1 provision ws-c2960s-24ps-l
ip domain-name localdomain
crypto pki trustpoint TP-self-signed-1464510976
subject-name cn=IOS-Self-Signed-Certificate-1464510976
rsakeypair TP-self-signed-1464510976
crypto pki certificate chain TP-self-signed-1464510976
30820249 308201B2 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
69666963 6174652D 31343634 35313039 3736301E 170D3933 30333031 30303032
33305A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 34363435
31303937 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100DF26 38F336C6 A25C6FDE 43B27C20 583B08B3 BE0133DB 7ED37C09 EBE7EA4F
16173FE7 E0FC1E3A 83864D35 D357DA47 E9261D92 C666F8DA 59297C32 E0013EF2
905AC018 4458DEF8 D3DA106C 458375B2 ABDF6180 E59E6C2C E2DD323C EEE6EBF2
C49F0055 481E050F 1DBA91AF 4C5940ED 19575A76 76BE5896 F838E7CC 90A1D0EF
869D0203 010001A3 71306F30 0F060355 1D130101 FF040530 030101FF 301C0603
551D1104 15301382 11536F75 74682E6C 6F63616C 646F6D61 696E301F 0603551D
23041830 16801403 DF2C382A DE81D8E7 A68EFB68 EFE61B13 20001B30 1D060355
1D0E0416 041403DF 2C382ADE 81D8E7A6 8EFB68EF E61B1320 001B300D 06092A86
4886F70D 01010405 00038181 006FC9BC 5CBE8C78 FBC34C39 9516CEF2 B7482C0E
0ED60AA9 F4146AC3 0307A511 204CB683 55361CF2 A4356FA8 7CB15B62 0EE1CA66
839C46B3 672490ED BAD963F8 32171AD3 7D545A37 029F63A7 2F405D7C 21669FF5
0248AA30 94CB0953 C528DF5F DF968A6D 75CF39F6 2FC1BB99 6BB21174 0719F886
FC1AE778 37301999 6F109328 39
quit
spanning-tree mode pvst
auto qos srnd4
vlan internal allocation policy ascending
ip ssh version 2
no ip address
interface GigabitEthernet1/0/1
description to 4 port swith for trotter67
switchport trunk allowed vlan 1,2
switchport mode trunk
interface GigabitEthernet1/0/2
description AP9 port
switchport trunk native vlan 37
switchport trunk allowed vlan 4-7,37
interface GigabitEthernet1/0/3
description access port for trotter68
interface GigabitEthernet1/0/4
description AP1 port
switchport trunk allowed vlan 3-7,37
interface GigabitEthernet1/0/5
switchport access vlan 3
switchport mode access
interface GigabitEthernet1/0/6
description AP6 port
interface GigabitEthernet1/0/7
description laptop/workstation
interface GigabitEthernet1/0/8
switchport access vlan 4
switchport port-security
switchport port-security aging time 2
switchport port-security violation restrict
switchport port-security aging type inactivity
macro description cisco-desktop
spanning-tree portfast
spanning-tree bpduguard enable
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
description wemo AP test port
switchport trunk allowed vlan 5,37
interface GigabitEthernet1/0/12
description seismo AP port
switchport trunk allowed vlan 8,37
interface GigabitEthernet1/0/13
description entertainment port (TV/DVDetc)
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
description AP port for NATA equipment
switchport trunk allowed vlan 9,37
interface GigabitEthernet1/0/23
switchport access vlan 6
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan1
ip address 192.168.1.3 255.255.255.0
interface Vlan2
ip address 192.168.2.3 255.255.255.0
interface Vlan3
ip address 192.168.3.3 255.255.255.0
interface Vlan4
ip address 192.168.4.3 255.255.255.0
interface Vlan5
ip address 192.168.5.3 255.255.255.0
interface Vlan6
ip address 192.168.6.3 255.255.255.0
interface Vlan7
ip address 192.168.7.3 255.255.255.0
interface Vlan8
ip address 192.168.8.3 255.255.255.0
interface Vlan9
ip address 192.168.9.3 255.255.255.0
interface Vlan37
ip address 192.168.37.3 255.255.255.0
ip default-gateway 192.168.1.1
ip http server
ip access-list extended Deny_TM-W-F7C033_DHCP
deny udp any any eq bootpc
deny udp any any eq bootps
permit ip any any
ip sla enable reaction-alerts
line con 0
line vty 0 4
login local
length 0
transport input ssh
line vty 5 15
login local
transport input ssh
end
8 Replies 8
I have looked at the configs and could not find any (obvious) errors. On the switch, you have two trunks:
Which one of these is actually connected to the AP ?
Also, since this is a layer 2 switch, what is the purpose of all the Vlan interfaces ?
btw:   I noticed these messages on the AP's log:
Interface Dot11Radio0, Deauthenticating Station d8c4.6a35.7e3b Reason: Sending station has left the BSS
Information Interface Dot11Radio0, Station d8c4.6a35.7e3b Associated KEY_MGMT[NONE]
It does connect to other vlans on a different AP
the log message indicates that the device has moved out of range. Do you have any other APs that are working ? If so, what are the speed and channel setting ?
That is strange,  I am about 3 feet away from the AP  and tried a phone and a laptop.  The APs that are working, are way further away
I use the web interface for the APs, but I can also ssh into hem.  How do I find the speeds in an ssh session? The channels are set to "least congested"
Yes, found it.  The setting on that AP is: speed 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
at this point, as there does not really seem to be an issue with the config, I would reset the AP to factory defaults, and start configuring it from scratch. Below is a link to a video that shows how to do that using the MODE button...
https://www.youtube.com/watch?v=eGCnTWBEpp8
Cisco_AP #Reset #IT_Support_People IT Support People Facebook Page: https://www.facebook.com/IT_Support-PeopleDesktop-Support-111268543923018 Link for Other Related Videos: Configure Cisco Access Point Standalone/Autonomous using GUI with WPAv2 Authentication Key: ...
I have done that a few times,  and used different APs
I was thinking about adding a DHCP pool, for just one mac/ip to that AP and see what happens,   but I can't find a simple example
roncro
Level 3
Level 3
Actually I configured both ports/trunks just in case there was something wrong with the port itself,  so I could switch the connection from port 24 to 22. The purpose of the vlans is to keep traffic separate,  IOT devices from servers, workstations
