VLAN & Policy Routing.
tauseef
Dear All,
Hope you can understand my scenario and give me suitable study
links / Configs to achieve the same.
I have a Core 4507 CAT doing 4 Vlans.
In frnot of that I have a Pix with 6 Port FE ( DMZ )
In front of that I have a Router with 4 Port FE for
which in turn is connected to ADSL routers.
Vlan A - 192.168.1.1-192.168.1.200
Vlan B- 192.168.2.1-192.168.2.200
Vlan C - 192.168.3.1 - 192.168.3.200
Vlan D - 192.168.4.1 - 192.168.4.200
Inter VLAN routing is definitely a must.
The Vlans A have gateway of 192.168.1.1 in Eth1 of Pix.
The Vlans B have gateway of 192.168.2.1 in DMZ1 of Pix.
The Vlans C have gateway of 192.168.3.1 in DMZ2 of Pix.
The Vlans D have gateway of 192.168.2.1 in DMZ3 of Pix.
All internet traffic comming through Vlan A to go through Router Eth0/1
All internet traffic comming through Vlan B to go through Router Eth0/2
All internet traffic comming through Vlan C to go through Router Eth0/3
All internet traffic comming through Vlan D to go through Router Serial 0
Tell me its possible, else I will kill some one in Cisco !
Please give me some links or better some sample configs if you have for
the same.
Thanks in Advance.
Rgds.
TA
devang_etcom
Level 7
Level 7
hi...
i think its easy to configure using the route maps...
first of all match your source ip address using the accesslist and then set the next hope of the appropriate router interface...
you can have configuration like this
access-list 1 permit 192.168.1.0 0.0.0.255
route-map vlan1 permit 10
match ip address 1 (accesslist number)
set ip next-hope YOUR ROUTER ETHERNET 0/1 INTERFACE IP ADDRESS
follow the same procedure for all the vlan...
hope this will work
rate this post if it works
regards
Devang
