VLAN routing on Layer 3 Catalyst 3560
scottcummins
Good day all
My first question is I have an access layer switch which is a single VLAN and I am trunking that VLAN to a distribution layer switch, I can ping the gateway on the distribution layer switch for THAT VLAN, But cannot ping the gateway address for the second VLAN I have on the distribution layer switch. I know it is simple, But I have forgotten and just need a push
Also I have a third VLAN set to  route traffic not bound for those 2 VLANs out to a router is the statement "ip route 0.0.0.0 0.0.0.0 172.16.252.2" good enough and do I actually need to create a VLAN for that traffic? and if so, is an access switchport the best option?
any and all responses welcome and greatly appreciated!!
Hello Scott,
Sounds like you haven't go the other vlan from the distribution switch in the vtp domain for either both switches or the access switch, Make sure your vtp config is correct and the vlans are being propagated.
you can just add the vlan.
conf t
vlan xxx
exit
sh vtp status
sh vlan brief
sh int trunk
res
Paul
Kind Regards
Paul
Abzal
Level 7
Level 7
It will be better if you post here 3560 switch configuration.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
