vlan's on router
tahir1234
Hi Seniors,
I understand that vlan's can be created on cisco switches but last day I was looking on the configuration of my office cisco router and I saw configuration on vlans interfaces. I ran the command "sh int vlan20" and I saw the interface. My questions
1-what are these vlan interfaces on router ?( if they are virtual , what is physical interface looks like for actual connection to router)
2-Is vlan interfaces different than virtual interfaces and how ?
3-How to configure vlan interfacs on router and for what purpose ?
4-What cisco router models that we can define vlans on ?
Thanks for reply. If someone knows a website the above explanation, I would appriciate.
Tahir.
Giuseppe Larosa
Hello Tahir,
modern IOS routers like 1800, 2800, 3800 series but also 3700 series and late 2600 can host small LAN switches modules.
My guess is that your router has one of them.
There two types of these modules:
those that are configured from the router itself
those that are a separate logical device with its own configuration.
in your case should be a module of first type.
So the questions can now be answered:
1) They are logical L3 interfaces so called SVI = switched virtual interfaces they provide layer 3 services (a gateway) to corresponding L2 Vlan.
the L2 vlan can be associated to one or multiple switch ports of the module and they are configured like in an IOS LAN switch.
2) Vlan interfaces are a form of logical interfaces like loopbacks but: an SVI vlan 10 can be up/up only if at least one switch port is up and associated to vlan 10 (including trunk ports and actually the correct definition is at least one port in Spanning tree state forwarding). Note: this is true for real switches it can be false for these modules on routers (the internal trunk between router and module can be enough to make the L3 SVI to stay up)
3)
First of all the corresponding L2 object Vlan has to be created, it is likely that you should use vlan database context
example:
router# vlan database
router(vlan)# vlan 10
router(vlan)# name test10
router(vlan)#apply
router(vlan)#exit
apply or exit are needed to have the new vlan created
then interface vlan 10 can be configured
config t
interface vlan 10
ip address 10.10.10.1 255.255.255.0
! you need to enable with no shut
no shut
ports in module can be associated to L2 broadcast domain vlan 10
int fas1/1
switchport
switchport mode access
switchport access vlan 10
the port can be used as a LAN switch port
4) as stated above multiservice routers (C3700, C2600) and ISR routers (1800,2800,3800) and new ISR G2 (1900,2900,3900) can host these modules
see
http://www.cisco.com/en/US/docs/ios/lanswitch/configuration/guide/lsw_hwic_ethsw_ic_ps6441_TSD_Products_Configuration_Guide_Chapter.html
Hope to help
Giuseppe
Giuseppe Larosa
Hello Tahir,
3)
example:
router(vlan)#apply
router(vlan)#exit
config t
interface vlan 10
no shut
int fas1/1
switchport
see
Hope to help
Giuseppe
Thanks Giuseppe
Explaination is really helpful.
Tahir.
ernest.johnson
Question SVI on a Router
I have the same situation going on, but my SVI interface is up down status
I have an HSRP environment and the primary router is providing the connectivity
when I look at the vlan database on the primary router the SVI interface is UP UP
The deference is that the vlan database contain the vlan in the vlan database.
Question
the secondary router SVI interface show UP DOWN is that because it does not have
the vlan interface in the vlan database. If so, once I add the vlan to the database; will the
SVI state chance to up up or is there any additional steps required to bring the interface
To an status of  UP UP
