vlan/subnetting and routing
johnj-20111
How do you conf the L3 switch so that wokstation 1, 2 and 3 can talk to each other with the following information?
VLAN A)  X.Y.123.128/255.255.255.192
VLAN B). X.Y.123.9/255.255.255.248
VLAN C) X.Y.123.0/255.255.255.252
Wks1) ip:  X.Y.123.132
Wks2) ip:  X.Y.123.10
Wks3) ip:  X.Y.123.2
Need to be able to ping and access to/from Wks1, Wks2 and Wks3.
paolo bevilacqua
Are you a student? Are you trying to get your homework done by others?
just want to learn...
I just got a few appliances to play with...
Can you help?
Wks3) ip:  X.Y.123.2
on your L3 switch you must :
-put interfaces going to each wrk in the correct vlan: switchport mode access , switchport access vlan X
-give an ip address to int vlanX:  int vlan x, ip address x.x.x.x "mask", no shut
-be sure ip routing is on: ip routing
then each wrk must have the ip add of int vlan as default gw
Regards.
Alain.
