VLAN
eandrcisco007
what is the best approach to trunk 4 different vlans to a vmware box?
michael o'nan
Level 4
Level 4
I'm assuming this is ESXi? Enable a trunk to the VMWare box - with the allowed VLANs (not required)
In ESXi follow this article that also provides configuration example for ESXi and the switch.
http://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=1004074
Awesome,thank you... by the same token, will it be considered for HyperV (win box) too?
Yes Hyper-V works similar. You would have a vSwitch in Hyper-V and can set VLANs per VM.
