10-13-2021 08:20 PM
Hi Friends,
I found following connectivity between vManage and vBond in my SD WAN Home Lab.
Please help me to understand why only one connection shows correct peer IP address in vBond and all others shows 0.0.0.0.
Thankyou very much for your support
10-14-2021 04:38 AM
Give us more information ? why Private IP all same ? (check other vedge config).
10-14-2021 04:43 AM
Thanks for the reply,This out put is from vManage not vEdge
10-14-2021 04:58 AM
YES we do understand the output from vManage, why all devices showing same IP ?
vBOND has so many DTLS tunnels with x.2 IP ?
10-14-2021 05:41 AM
As per my understanding between vManage and VBond multple DTLS connections will be created and the number of connections are equal to the number of cores in the vManage.I used eight vCPUs in the vManage and thats why we have eight connections.My issue is why only one connection shows the correct IPs while other 7 connection show 0.0.0.0.
