voice and data communication over IP Network
almamun
Dear All,
I have two AS5350 with 4E1-PRI. I want to build up the below topology. If possible, Please give me some sample config.
PBX<---E1--->AS5350---IP Network---AS5350<--E1--->PBX
Mamun
paolo bevilacqua
Hi, for a primer search "understanding dial-peer" then you have the documentation with many many examples. Youe E1 ports will internat clock and network-side. Use crossed cables to PBXs.
