Voice QoS
We have two sites, with fibre broadband at both sites (40/10Mbps). One site has a UC500 that hosts 6 phones and 2 phones connect remotely via IPSec VPN on a Cisco 887VA router.
I am trying to apply QoS for the voice traffic for best performance over VPN but getting stuck as to where I should be applying the policy map.
This is a config snippet of the remote site router:
class-map match-all voice
 match protocol skinny
 match protocol sip
class-map match-all rtp
 match protocol rtp
policy-map voip
 class rtp
  priority 300
 class voice
  priority 100
 class class-default
  police 500000
interface Ethernet0
 no ip address
interface Ethernet0.101
 description **BT Fibre**
 encapsulation dot1Q 101
 pppoe enable group global
 pppoe-client dial-pool-number 1
interface Dialer0
 bandwidth 8000
 ip address negotiated
 no ip proxy-arp
 ip mtu 1492
 ip nbar protocol-discovery
 ip flow ingress
 ip nat outside
 ip virtual-reassembly in
 encapsulation ppp
 ip tcp header-compression iphc-format
 dialer pool 1
 dialer-group 1
 ppp authentication chap pap callin
 ppp chap hostname
 ppp chap password
 ppp pap sent-username
 ppp ipcp route default
 no cdp enable
 ip rtp header-compression iphc-format
Am I on the right path? Should I apply the service-policy to the Dialer 0 for outgoing traffic or incoming?
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
It's been years since I've worked with a dialer interface, so I'm unsure where QoS should be applied.  However, if you're working with bandwidth less that port bandwidth, you should shape for it, otherwise your QoS will only "engage" when the port, itself, congests.  Also, normally you work to provide egress QoS on both sides.
If you can manage both sides egress, especially with shaping, there's often rarely need to "police" traffic, as you're doing in your class-default.
