voip over MPLS
winston123
guys, i have an mpls bet ny-uk,but my voip provider is a different one, i have a public ip given by my voip provider where i need to send traffic to, it is not working, should configure my 2811 with the public ip or my private ip.
I am trying to send voip traffice over the public internet,no p-to-p connection with my voip provider.
Thx
NetworkNY:2811->switch->fw->10mb mpls->
ciscocow
Could you be a bit more clear in what you are trying to do?
are you trying to do
2811NY-->MPLS<--2811UK
or
2811-->Internet<--2811UK
Because if you are trying to use your MPLS to connect to your Internet VOIP Provider then that will not work unless you are getting fed an Internet route via the MPLS Cloud. You need to provide a bit more detail to get a correct answer.
Thanks for the quick reply. i am trying to do:
2811-->mpls->internet->voip provider.
I do have an internet feed via the MPLS,which happens to be fed by my same voip provider for another 2811/voip connection (this is totally seperate from my MPLS)the 2nd 2811 is phycally in the UK and it works fine, sending calls over the 10mb ethernet link bet my location and my voip provider in UK. I now have a 2811 here in NY,and i try to send traffic from the 2811 here using my MPLS.
I hope this gives you a more clear picture.
Note: I use the same FW and switch for my MPLS as well as for the 10mb ethernet for internet access.
Thanks.
So you have a seperate connection for internet, it is not provided via the MPLS link? If that is the case you will need to use the public ip ont e 2811
/--(private)-->MPLS<--2811UK
2811
\--(Public)-->Internet<--VOIP
Is this what is should look like if i understand what you have
Ok, i understand now.thanks a lot. I will implement as suggested.
