vpdn l2tp internal network cannot ping
kev_mas01
Level 2
Level 2
i have the below config on the router VPN from windows 10 pc is connected but cannot ping internal network please guide me
aaa new-model
aaa authentication login default local
aaa authentication login telnet local
aaa authorization exec default local
aaa session-id common
transport-map type persistent telnet telnethandler
connection wait none
ip name-server 84.X.X.55 84.XX.X.230
vpdn enable
vpdn-group l2tp
! Default L2TP VPDN group
accept-dialin
protocol l2tp
virtual-template 1
no l2tp tunnel authentication
crypto isakmp policy 1
encryption 3des
authentication pre-share
group 2
lifetime 3600
crypto isakmp key cisco address 0.0.0.0 no-xauth
crypto isakmp client configuration group cisco
key cisco123
pool vpnpool
crypto ipsec transform-set myset esp-3des esp-sha-hmac
mode transport
crypto dynamic-map mymap 1
set nat demux
set transform-set myset
reverse-route
crypto map mymap client configuration address respond
crypto map mymap 1 ipsec-isakmp dynamic mymap
interface Loopback1
ip address 192.168.160.1 255.255.255.0
interface GigabitEthernet0/0/0
ip address 51.X.X.247 255.255.255.0
ip nat outside
negotiation auto
crypto map mymap
interface GigabitEthernet0/0/1
ip address 10.10.40.1 255.255.255.0
ip nat inside
media-type rj45
negotiation auto
interface GigabitEthernet0/0/2
ip address 10.0.2.2 255.255.255.0
ip nat inside
media-type sfp
negotiation auto
vrf forwarding Mgmt-intf
ip address 50.50.50.1 255.255.255.0
negotiation auto
interface Virtual-Template1
ip unnumbered Loopback1
ip nat inside
peer default ip address pool vpnpool
ppp encrypt mppe 128
ppp authentication ms-chap-v2
router ospf 1
network 10.10.40.1 0.0.0.0 area 0
network 51.211.161.247 0.0.0.0 area 0
ip local pool PP 192.168.0.10 192.168.0.15
ip local pool vpnpool 192.168.160.1 192.168.160.10
ip http server
ip http secure-server
ip forward-protocol nd
ip nat inside source list natlist interface GigabitEthernet0/0/0 overload
ip route 0.0.0.0 0.0.0.0 51.X.X.246
ip route 10.0.0.0 255.255.255.0 10.0.2.1
ip route 10.0.1.0 255.255.255.0 10.0.2.1
ip route 10.0.2.0 255.255.255.0 10.0.2.1
ip route 10.0.3.0 255.255.255.0 10.0.2.1
ip route 10.0.4.0 255.255.255.0 10.0.2.1
ip route 10.10.50.0 255.255.255.0 10.10.40.2
ip route 10.100.0.0 255.255.255.0 10.0.2.1
ip route 10.110.0.0 255.255.255.0 10.0.2.1
ip route 10.120.0.0 255.255.255.0 10.0.2.1
ip route 20.20.20.0 255.255.255.0 10.10.40.2
ip route 192.168.1.0 255.255.255.0 10.0.2.1
ip route 192.168.10.0 255.255.255.0 10.0.2.1
ip route 192.168.50.0 255.255.255.0 10.10.40.2
ip route 192.168.160.0 255.255.255.0 10.10.40.2
ip access-list extended natlist
10 permit ip 10.10.20.0 0.0.0.255 any
20 permit ip 10.0.2.0 0.0.0.255 any
30 permit ip 10.0.3.0 0.0.0.255 any
40 permit ip 10.0.4.0 0.0.0.255 any
50 permit ip 10.100.0.0 0.0.0.255 any
60 permit ip 10.110.0.0 0.0.0.255 any
70 permit ip 10.120.0.0 0.0.0.255 any
80 permit ip 10.0.0.0 0.0.0.255 any
90 permit ip 10.0.1.0 0.0.0.255 any
100 permit ip 192.168.10.0 0.0.0.255 any
110 permit ip 192.168.50.0 0.0.0.255 any
120 permit ip 10.10.30.0 0.0.0.255 any
130 permit ip 192.168.40.0 0.0.0.255 any
140 permit ip 192.168.2.0 0.0.0.255 any
150 permit ip 20.20.20.0 0.0.0.255 any
160 permit ip 10.10.40.0 0.0.0.255 any
170 permit ip 10.10.50.0 0.0.0.255 any
180 permit ip 192.168.3.0 0.0.0.255 any
190 permit ip 192.168.160.0 0.0.0.255 any
200 permit ip 192.168.1.0 0.0.0.255 any
Please guide me to able to ping to internal network 10.10.40.2 as i have my core switch connected on this port
72 Replies 72
yes you must reconnect the window l2tp to this router, after that you will get the PPP log message.
so can you reconnect now.
i did reconnect it .. still no logs generated at all nothing on the router screen
I HAVE DONE THE SAME CONFIG AND I M SELECTING L2TP/IPSEC FOR CONNECTION..BUT STILL WILL TRY THIS CONFIG TO WRITE AGAIN
I check your original post config, for L2TP it OK but for IPSec it need some change,
please see the change in my config try it.
aaa authentication ppp default local
ip name-server 84.235.6.55 84.235.57.230
login on-success log
vpdn enable
vpdn-group l2tp
accept-dialin
protocol l2tp
virtual-template 1
no device-tracking logging theft
crypto pki trustpoint SLA-TrustPoint
enrollment pkcs12
revocation-check crl
crypto pki certificate pool
cabundle nvram:ios_core.p7b
license feature hseck9
license udi pid ISR4331/K9 sn FDO24370BT3
license boot level appxk9
license boot level securityk9
license smart transport callhome
memory free low-watermark processor 69096
diagnostic bootup level minimal
username admin privilege 15 password 0 kevin
username atheervpn password 0 cisco
username cisco password 0 cisco
redundancy
mode none
crypto vpn anyconnect bootflash:/webvpn/anyconnect-win-4.9.03047-webdeploy-k9.pkg sequence 1
crypto isakmp policy 10
encryption 3des
group 2
lifetime 3600
crypto isakmp keepalive 3600
crypto ipsec transform-set vpn esp-3des esp-sha-hmac
mode transport
crypto dynamic-map mymap 10
set nat demux
set transform-set vpn
crypto map cisco 10 ipsec-isakmp dynamic mymap
ip nat outside
negotiation auto
crypto map cisco
ip nat inside
media-type rj45
negotiation auto
ip nat inside
media-type sfp
negotiation auto
negotiation auto
ip unnumbered GigabitEthernet0/0/0
router ospf 1
network 51.X.X.247 0.0.0.0 area 0
ip local pool SSLVPN_POOL 192.168.11.1 192.168.11.10
ip local pool vpnpool 192.168.150.1 192.168.150.10
ip http server
ip http authentication aaa
ip route 0.0.0.0 0.0.0.0 51.211.161.246
control-plane
line con 0
password
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password kevin
transport input telnet
call-home
! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
active
destination transport-method h
Still i have the same port is closed error...this problem happened only after i activated the appxk9 feature and reloaded the router
Device manager > network adapter > uninstall the miniport
and try connect again
yes i have done it correctly ..
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 appxk9 Smart License appxk9
uck9 None Smart License None
securityk9 securityk9 Smart License securityk9
ipbase ipbasek9 Smart License ipbasek9
show license udi
can I see the output for this?
UDI: PID:ISR4331/K9,SN:FDO24370BT3
i have tried uninstall miniport also and done today.. still same error i dont understand what is wrong.. do you think the service provider has blocked this .. is that possible.. as far as i know that should not be a problem
