11-21-2020 11:34 PM
i have the below config on the router VPN from windows 10 pc is connected but cannot ping internal network please guide me
aaa new-model
aaa authentication login default local
aaa authentication login telnet local
aaa authorization exec default local
aaa session-id common
transport-map type persistent telnet telnethandler
connection wait none
ip name-server 84.X.X.55 84.XX.X.230
vpdn enable
vpdn-group l2tp
! Default L2TP VPDN group
accept-dialin
protocol l2tp
virtual-template 1
no l2tp tunnel authentication
crypto isakmp policy 1
encryption 3des
authentication pre-share
group 2
lifetime 3600
crypto isakmp key cisco address 0.0.0.0 no-xauth
crypto isakmp client configuration group cisco
key cisco123
pool vpnpool
crypto ipsec transform-set myset esp-3des esp-sha-hmac
mode transport
crypto dynamic-map mymap 1
set nat demux
set transform-set myset
reverse-route
crypto map mymap client configuration address respond
crypto map mymap 1 ipsec-isakmp dynamic mymap
interface Loopback1
ip address 192.168.160.1 255.255.255.0
interface GigabitEthernet0/0/0
ip address 51.X.X.247 255.255.255.0
ip nat outside
negotiation auto
crypto map mymap
interface GigabitEthernet0/0/1
ip address 10.10.40.1 255.255.255.0
ip nat inside
media-type rj45
negotiation auto
interface GigabitEthernet0/0/2
ip address 10.0.2.2 255.255.255.0
ip nat inside
media-type sfp
negotiation auto
vrf forwarding Mgmt-intf
ip address 50.50.50.1 255.255.255.0
negotiation auto
interface Virtual-Template1
ip unnumbered Loopback1
ip nat inside
peer default ip address pool vpnpool
ppp encrypt mppe 128
ppp authentication ms-chap-v2
router ospf 1
network 10.10.40.1 0.0.0.0 area 0
network 51.211.161.247 0.0.0.0 area 0
ip local pool PP 192.168.0.10 192.168.0.15
ip local pool vpnpool 192.168.160.1 192.168.160.10
ip http server
ip http secure-server
ip forward-protocol nd
ip nat inside source list natlist interface GigabitEthernet0/0/0 overload
ip route 0.0.0.0 0.0.0.0 51.X.X.246
ip route 10.0.0.0 255.255.255.0 10.0.2.1
ip route 10.0.1.0 255.255.255.0 10.0.2.1
ip route 10.0.2.0 255.255.255.0 10.0.2.1
ip route 10.0.3.0 255.255.255.0 10.0.2.1
ip route 10.0.4.0 255.255.255.0 10.0.2.1
ip route 10.10.50.0 255.255.255.0 10.10.40.2
ip route 10.100.0.0 255.255.255.0 10.0.2.1
ip route 10.110.0.0 255.255.255.0 10.0.2.1
ip route 10.120.0.0 255.255.255.0 10.0.2.1
ip route 20.20.20.0 255.255.255.0 10.10.40.2
ip route 192.168.1.0 255.255.255.0 10.0.2.1
ip route 192.168.10.0 255.255.255.0 10.0.2.1
ip route 192.168.50.0 255.255.255.0 10.10.40.2
ip route 192.168.160.0 255.255.255.0 10.10.40.2
ip access-list extended natlist
10 permit ip 10.10.20.0 0.0.0.255 any
20 permit ip 10.0.2.0 0.0.0.255 any
30 permit ip 10.0.3.0 0.0.0.255 any
40 permit ip 10.0.4.0 0.0.0.255 any
50 permit ip 10.100.0.0 0.0.0.255 any
60 permit ip 10.110.0.0 0.0.0.255 any
70 permit ip 10.120.0.0 0.0.0.255 any
80 permit ip 10.0.0.0 0.0.0.255 any
90 permit ip 10.0.1.0 0.0.0.255 any
100 permit ip 192.168.10.0 0.0.0.255 any
110 permit ip 192.168.50.0 0.0.0.255 any
120 permit ip 10.10.30.0 0.0.0.255 any
130 permit ip 192.168.40.0 0.0.0.255 any
140 permit ip 192.168.2.0 0.0.0.255 any
150 permit ip 20.20.20.0 0.0.0.255 any
160 permit ip 10.10.40.0 0.0.0.255 any
170 permit ip 10.10.50.0 0.0.0.255 any
180 permit ip 192.168.3.0 0.0.0.255 any
190 permit ip 192.168.160.0 0.0.0.255 any
200 permit ip 192.168.1.0 0.0.0.255 any
Please guide me to able to ping to internal network 10.10.40.2 as i have my core switch connected on this port
Solved! Go to Solution.
12-01-2020 09:25 AM - edited 12-01-2020 09:48 AM
Thanks for the information supplied. I regret I have not emphasized I am interested to see the router commands output at the time VPN client is connected - my fault.
Can you please add the following line at the beginning of the ip access-list extended natlist:
"5 deny ip any 172.31.1.0 0.0.0.255"
and try to ping your router local interfaces (from the VPN connected PC) with the "Use default gateway on remote network" parameter of your WAN miniport L2TP set (ie.default).
Best regards,
Antonin
12-01-2020 10:37 AM
I am so so happy for you, good work friends
for split tunnel please see this link
https://support.zyxel.eu/hc/en-us/articles/360001121480-L2TP-Over-IPSEC-VPN-Split-Tunneling.
good luck friend.
11-22-2020 12:26 AM - edited 11-22-2020 12:44 AM
As per my understanding, you able to ping 10.10.40.2 and not able to ping other Local LAN Address space is this correct ( before i can go through the configuration you posted ?)
if you able to ping 10.10.40.2 - Do you have a route back From 10.10.40.2 to 10.10.40.1 for the below address space? ( or you learning this route any other method ?)
Other Observation :
You Need to Deny the VPN traffic in the NAT ACL. (192.168.160.1 192.168.160.10) and apply the correct split tunnel. ( hope you only looking to access Lan resources and send internet traffic locally breakout ?)
11-22-2020 02:01 AM
hi there is another extreme coreswitch connected to the router isr 4331
so the static routes are for those network .
i cant ping 10.10.40.1 or 10.10.40.2
11-22-2020 02:10 AM
can you please guide me with command what changes i will need to make for denying and making split tunnel
11-22-2020 02:17 AM
i only want to access local resources on lan not internet.. i dont want internet traffic via vpn tunnel only need to access local system resources.. please guide me accordingly what changes i have to make for it to work
11-22-2020 01:21 AM
I cannot really figure out what all the static routes are for. With only a default route, you should be able to access at least the connected networks. At the very least, delete this route:
--> no ip route 192.168.160.0 255.255.255.0 10.10.40.2
Also, change the IP address of the Loopback interface so it is not part of the VPDN pool, e.g.:
interface Loopback1
ip address 172.16.1.1 255.255.255.0
11-22-2020 02:06 AM
let me remove the static route and the loopback interface changed ..still not being able to ping loopback also from the client windows 10.
11-22-2020 02:09 AM
what CAN you ping from your Windows PC ? Can you access the Internet ?
11-22-2020 02:12 AM
yes i can access internet and ping the public ip of the router thats it..
i cant ping the 10.10.40.1 thats the router port ip and my core switch ip is 10.10.40.2
11-22-2020 02:13 AM
What IP address is your PC getting ?
11-22-2020 02:15 AM
11-22-2020 02:58 AM
I cannot really see anything wrong with either configuration. Try and disable the Windows firewall.
11-22-2020 11:11 PM
hi i need to reboot to activate appxk9 license but till yest i was able to connect to vpn after reboot now i m getting the message on windows pc stating that " a connection to remote computer could not established , so the port used for this connection was closed"
I dont understand this error at alll Please help
11-23-2020 02:45 AM - edited 12-01-2020 09:54 AM
11-23-2020 04:26 AM
i just did debug ppp negotiation
it just says debuggin is on
after that nothing
