11-21-2020 11:34 PM
i have the below config on the router VPN from windows 10 pc is connected but cannot ping internal network please guide me
aaa new-model
aaa authentication login default local
aaa authentication login telnet local
aaa authorization exec default local
aaa session-id common
transport-map type persistent telnet telnethandler
connection wait none
ip name-server 84.X.X.55 84.XX.X.230
vpdn enable
vpdn-group l2tp
! Default L2TP VPDN group
accept-dialin
protocol l2tp
virtual-template 1
no l2tp tunnel authentication
crypto isakmp policy 1
encryption 3des
authentication pre-share
group 2
lifetime 3600
crypto isakmp key cisco address 0.0.0.0 no-xauth
crypto isakmp client configuration group cisco
key cisco123
pool vpnpool
crypto ipsec transform-set myset esp-3des esp-sha-hmac
mode transport
crypto dynamic-map mymap 1
set nat demux
set transform-set myset
reverse-route
crypto map mymap client configuration address respond
crypto map mymap 1 ipsec-isakmp dynamic mymap
interface Loopback1
ip address 192.168.160.1 255.255.255.0
interface GigabitEthernet0/0/0
ip address 51.X.X.247 255.255.255.0
ip nat outside
negotiation auto
crypto map mymap
interface GigabitEthernet0/0/1
ip address 10.10.40.1 255.255.255.0
ip nat inside
media-type rj45
negotiation auto
interface GigabitEthernet0/0/2
ip address 10.0.2.2 255.255.255.0
ip nat inside
media-type sfp
negotiation auto
vrf forwarding Mgmt-intf
ip address 50.50.50.1 255.255.255.0
negotiation auto
interface Virtual-Template1
ip unnumbered Loopback1
ip nat inside
peer default ip address pool vpnpool
ppp encrypt mppe 128
ppp authentication ms-chap-v2
router ospf 1
network 10.10.40.1 0.0.0.0 area 0
network 51.211.161.247 0.0.0.0 area 0
ip local pool PP 192.168.0.10 192.168.0.15
ip local pool vpnpool 192.168.160.1 192.168.160.10
ip http server
ip http secure-server
ip forward-protocol nd
ip nat inside source list natlist interface GigabitEthernet0/0/0 overload
ip route 0.0.0.0 0.0.0.0 51.X.X.246
ip route 10.0.0.0 255.255.255.0 10.0.2.1
ip route 10.0.1.0 255.255.255.0 10.0.2.1
ip route 10.0.2.0 255.255.255.0 10.0.2.1
ip route 10.0.3.0 255.255.255.0 10.0.2.1
ip route 10.0.4.0 255.255.255.0 10.0.2.1
ip route 10.10.50.0 255.255.255.0 10.10.40.2
ip route 10.100.0.0 255.255.255.0 10.0.2.1
ip route 10.110.0.0 255.255.255.0 10.0.2.1
ip route 10.120.0.0 255.255.255.0 10.0.2.1
ip route 20.20.20.0 255.255.255.0 10.10.40.2
ip route 192.168.1.0 255.255.255.0 10.0.2.1
ip route 192.168.10.0 255.255.255.0 10.0.2.1
ip route 192.168.50.0 255.255.255.0 10.10.40.2
ip route 192.168.160.0 255.255.255.0 10.10.40.2
ip access-list extended natlist
10 permit ip 10.10.20.0 0.0.0.255 any
20 permit ip 10.0.2.0 0.0.0.255 any
30 permit ip 10.0.3.0 0.0.0.255 any
40 permit ip 10.0.4.0 0.0.0.255 any
50 permit ip 10.100.0.0 0.0.0.255 any
60 permit ip 10.110.0.0 0.0.0.255 any
70 permit ip 10.120.0.0 0.0.0.255 any
80 permit ip 10.0.0.0 0.0.0.255 any
90 permit ip 10.0.1.0 0.0.0.255 any
100 permit ip 192.168.10.0 0.0.0.255 any
110 permit ip 192.168.50.0 0.0.0.255 any
120 permit ip 10.10.30.0 0.0.0.255 any
130 permit ip 192.168.40.0 0.0.0.255 any
140 permit ip 192.168.2.0 0.0.0.255 any
150 permit ip 20.20.20.0 0.0.0.255 any
160 permit ip 10.10.40.0 0.0.0.255 any
170 permit ip 10.10.50.0 0.0.0.255 any
180 permit ip 192.168.3.0 0.0.0.255 any
190 permit ip 192.168.160.0 0.0.0.255 any
200 permit ip 192.168.1.0 0.0.0.255 any
Please guide me to able to ping to internal network 10.10.40.2 as i have my core switch connected on this port
Solved! Go to Solution.
11-24-2020 07:20 PM
AtheerISR#sh license all
Smart Licensing Status
Smart Licensing is ENABLED
License Conversion:
Automatic Conversion Enabled: False
Status: Not started
Export Authorization Key:
Features Authorized:
<none>
Utility:
Status: DISABLED
Smart Licensing Using Policy:
Status: ENABLED
Data Privacy:
Sending Hostname: yes
Callhome hostname privacy: DISABLED
Smart Licensing hostname privacy: DISABLED
Version privacy: DISABLED
Transport:
Type: Callhome
Miscellaneous:
Custom Id: <empty>
Policy:
Policy in use: Merged from multiple sources.
Reporting ACK required: yes (CISCO default)
Unenforced/Non-Export Perpetual Attributes:
First report requirement (days): 365 (CISCO default)
Reporting frequency (days): 0 (CISCO default)
Report on change (days): 90 (CISCO default)
Unenforced/Non-Export Subscription Attributes:
First report requirement (days): 90 (CISCO default)
Reporting frequency (days): 90 (CISCO default)
Enforced (Perpetual/Subscription) License Attributes:
First report requirement (days): 0 (CISCO default)
Report on change (days): 0 (CISCO default)
Export (Perpetual/Subscription) License Attributes:
Usage Reporting:
Last ACK received: <none>
Next ACK deadline: Nov 16 06:25:01 2021 UTC
Reporting push interval: 30 days
Next ACK push check: <none>
Next report push: Nov 24 15:01:31 2020 UTC
Last report push: <none>
Last report file write: <none>
Trust Code Installed: <none>
License Usage
appxk9 (ISR_4331_Application):
Description: appxk9
Count: 1
Version: 1.0
Status: IN USE
Export status: NOT RESTRICTED
Feature Name: appxk9
Feature Description: appxk9
Enforcement type: NOT ENFORCED
License type: Perpetual
securityk9 (ISR_4331_Security):
Description: securityk9
Count: 1
Version: 1.0
Status: IN USE
Feature Name: securityk9
Feature Description: securityk9
Product Information
UDI: PID:ISR4331/K9,SN:FDO24370BT3
Agent Version
Smart Agent for Licensing: 5.0.6_rel/47
License Authorizations
Overall status:
Active: PID:ISR4331/K9,SN:FDO24370BT3
Status: NOT INSTALLED
Status:PAK
Legacy License Info:
regid.2014-12.com.cisco.ISR_4331_Security,1.0_dba7c7eb-f2b3-4824-9690-10e46d998fa5:
DisplayName: securityk9
Total available count: 1
Term information:
License type: PERPETUAL
Term Count: 1
Please check if its activated..
11-26-2020 01:52 AM
i tried ...
sh license summary
License Usage:
License Entitlement Tag Count Status
appxk9 (ISR_4331_Application) 1 IN USE
securityk9 (ISR_4331_Security) 1 IN USE
This is the licenses active..
sh license usage
License Authorization:
Status: Not Applicable
Description: appxk9
Count: 1
Version: 1.0
Status: IN USE
Count: 1
Version: 1.0
Status: IN USE
i feel there is some issue with the configuration or the ios image needs to be changed to the stable version. because i feel that ios image i had put is he amsterdam one...i m thinking to downgrade to 16.9
11-26-2020 12:48 PM
Thanks for the response. While I have checked the bug tool and have not identified any bug which could be related I think it is a good idea to downgrade. As I have already mentioned my lab setup using your router configuration works just fine but at the moment I have not your router model available so I am using a different box with another IOS release.
I would be interested to see the "debug cry isakmp" and "debug cry ipsec" outputs taken when VPN connection is attempted - please beware these are rather chatty.
Best regards,
Antonin
11-28-2020 10:44 PM
11-28-2020 10:44 PM
11-29-2020 03:28 AM - edited 12-01-2020 09:48 AM
11-29-2020 09:55 PM
11-30-2020 06:08 AM
11-29-2020 12:15 PM
Thanks for the information supplied. The indication of your issue is almost at the end of the debug:
"%FMANRP_ESS-4-FULLVAI: Session creation failed due to Full Virtual-Access Interfaces not being supported. ......"
There are couple of bugs found relating this message but none fits exactly to your box. Before we go any further can you please post your current router configuration as I understand you have changed it several times since the original one. Please BEWARE that up to now you have published quite a lot of the sensitive information as for your configuration so PLEASE change at least your authentication data (ie. username/password) with the IMMEDIATE EFFECT and do not publish these any more.
Thanks & Regards,
Antonin
11-29-2020 09:54 PM
11-30-2020 02:45 AM - edited 11-30-2020 02:46 AM
Thanks for the reply and the information supplied. Will you please adjust your current router configuration as per beneath:
1) Please change your pre-shared key (cisco) to another secret (both sides) and do NOT publish this any more.
2) Please add the command "reverse-route" under the "crypto dynamic-map ipnet-map 10".
3) Please add the command "ip nat inside" under the "interface Virtual-Template2".
4) Please add the command "permit ip 172.10.1.0 0.0.0.255 any" under the "ip access-list extended natlist".
5) Please check your WAN miniport L2TP configuration as follows: Properties > Networking tab > double click on IPv4 > click Advanced > check Use default gateway on remote network (default setting).
If still experiencing VPN error 619 can you please post the debug output (debug cry isakmp, debug cry ipsec, debug ppp negot) taken when VPN is initiated.
Thanks & Regards,
Antonin
11-30-2020 06:10 AM
11-30-2020 11:56 AM
Thanks for the reply. Can you please try to remove the configuration command "ppp encrypt mppe 40" under the "interface Virtual-Template2" and try again.
Thanks & Regards,
Antonin
11-30-2020 09:04 PM
hey, thanks when i remove ppp encrypt it now connects great !!!
but i have another small issue is that cannot ping my internal network...Please guide me for that
12-01-2020 12:55 AM
Thanks for the update. Can you please post the "sh ip int br" and "sh ip rou" commands output (router) and also "ipconfig /all" (PC).
Best regards,
Antonin
