VPN as failover to WAN link(s)
Steve Coady
Hello
I have a Data Center with an outsource company and a WAN link to them over an AVPN cloud connection
I have (12) sites around the country each with their own connection to the same AVPN cloud as data center.
We suffered an outage on the Data center WAN interface due to lack of redundancy.
In the event that this happens again, To bypass the Data Center WAN interface as a short term fail over fix, I want to create a VPN connection from my Corpoarate site (used to be my data center before outsource) to the data Center.
Creating the VPN is easy enough and defining the networks to be allowed across. I can create the fw rule is asdm and as long as I don't enable it, there should be no problem with routing issues.
I am wondering what route statement I need to create in each of the 12 site routers that will send data to my Corporate site where it can then be sent over VPN, once the ASA rules is enabled.
Is then even the best short term approach?
sMc
Lei Tian
So the temp solution is to have ipsec VPN tunnel between data center and corp office, this VPN tunnel will be used as backup link when data center primary WAN link fails. What routing protocol are you running across WAN? What routing protocol are you going to run across the VPN tunnel? Are you advertising default from corp or data enter? Can you summarize prefixes from data center?
HTH,
Lei Tian
7 Replies 7
Lei Tian
HTH,
Lei Tian
Lei
Thank you for the response.
What routing protocol are you running across WAN?                          Answer BGP
What routing protocol are you going to run across the VPN tunnel?     IPSec (site-to-Site)
Are you advertising default from corp or data enter?                            Answer Not at this time
Can you summarize prefixes from data center?                                  We could i guess. They are contiguous.
        They are not currently aggregated in the Protected
        Networks field.
sMc
sMc
Sorry
the above image is our network topology
sMc
Hi Steve,
Thanks for the info. Based on your setup, you can advertise datacenter summary route from corp to BGP, and adversie corp summary route from datacenter to BGP. This BGP route will propogate to remotes, and will be used as backup path when remote loses the more specifc routes from BGP.
HTH,
Lei Tian
Lei
Thank you for the response. Greatly appreciated.
I am not sure how the commnds would look. Here are the BGP stements for the Data center router and the Corp site along with statics. At your earliest convenience please review and advise.
CORP Router
router bgp 43210
no bgp log-neighbor-changes
network 0.0.0.0
network 10.x.16.0 mask 255.255.240.0
network 10.x.32.0 mask 255.255.240.0
network 192.168.h.0
network 192.168.i.0
network 192.168.j.0
network 192.168.k.0
network 192.168.l.0
network 192.168.m.0
network 192.168.n.0
network 192.168.o.0
network 192.168.p.0
neighbor 172.16.x.x remote-as 56789
neighbor 172.16.x.x soft-reconfiguration inbound
neighbor 172.16.x.x route-map PrependNetgate in
no auto-summary
ip route 0.0.0.0 0.0.0.0 192.168.j.1 track 2
ip route 192.168.k.0 255.255.255.0 192.168.j.1  track 2
ip route 192.168.n.0 255.255.255.0 192.168.j.2 track 2
ip route 192.168.o.0 255.255.255.0 192.168.j.2 track 2
ip route 192.168.253.0 255.255.255.0 192.168.3. track 2
Data Center router
router bgp 01234
redistribute static
no auto-summary
ip route 192.168.a.0 255.255.255.0 172.16.y.z
ip route 192.168.b.0 255.255.255.0 172.16.y.z
ip route 192.168.c.0 255.255.255.0 172.16.y.z
ip route 192.168.d.0 255.255.255.0 172.16.y.z
ip route 192.168.e.0 255.255.255.0 172.16.y.z
sMc
The final solution for this specific problem will be:
When connectivity to MY_remote_Data_Center is lost, an alternate routing path will direct traffic from the MY_Company network toward the Internet.
The VPN would be established between the MY_Company_ASAs and MY_remote_Data_Center firewall. The VPN connection has to be manually activated on MY_remote_Data_Center.
A Customer SLA accompany's this solution to guarantee response times.
This sequesnce is for implementation annd initial test
object network MY_remote_Data_Center
host 192.168.y.a
object network MY_Company
host 192.168.z.a
access-list MY_remote_Data_Center_cryptomap line 1 extended permit ip object MY_Company-Network object MY_remote_Data_Center
group-policy GroupPolicy_MY_remote_Data_Center internal
group-policy GroupPolicy_MY_remote_Data_Center attributes
vpn-tunnel-protocol ikev1
exit
tunnel-group 1.1.1.1 type ipsec-l2l !<< obviously Replace 1.1.1.1 with the MY_remote_Data_Center VPN IP Address
tunnel-group 1.1.1.1 general-attributes
default-group-policy GroupPolicy_MY_remote_Data_Center
tunnel-group 1.1.1.1 ipsec-attributes
ikev1 pre-shared-key <>
isakmp keepalive threshold 10 retry 2
crypto map outside_map 4 match address MY_remote_Data_Center_cryptomap
crypto map outside_map 4 set  peer  1.1.1.1 !<< obviously Replace 1.1.1.1 with the MY_remote_Data_Center VPN IP Address
crypto map outside_map 4 set  ikev1 transform-set  ESP-AES-256-SHA
Once the above solution has been validated. the loopback ip addresses would be removed and actual production subnets added
sMc
