VPN Client 3.0.4 (C) fails behind 501
tfiorda
I have just recently switched to using a pix 501 from a Linksys RVS4000. Using the RVS4000, I was able to establish an IPSEC VPN through that fw, but I've been unable to get the configuration correct for the PIX 501. It is supposed to support IPSEC Passthrough to allow the VPN.
The Connection establishes but I don't get any response from the remote. Probably because of the NAT that is happening.
Is there a way to configure the 501 to allow two way communication using the VPN client behind it? BTW, I am connecting to another 501 in the remote location.
Tony...
16 Replies 16
I was able to resolve this issue by adding the following command on my ASA that was acting as the VPN server.
isakmp nat-traversal 20
Hope that helps!
Well, I've tried that before, BUT...no one said it needed to be at the far end. Since I am going through one Pix to terminate the tunnel at another, and it worked fine if the VPN Client was in the wild (internet connected outside of the firewall), I didn't suspect the far end being the problem. I should have though.
I added that statement to both side and now I have data passing and can get to the resources at the other end.
Thanks for adding the statement, "acting as the VPN server". That did it!
Tony...
