VPN client connects to ASA 5510 but...
sean.hammond
I have a dozen or so users connecting to an ASA 5510 via Cisco VPN client v5.0.00.0340 - this works successfully for all but one user. This user is able to authenticate to the ASA but unable to pass traffic once authenticated. He is able to send/receive traffic after someone on the inside of the network initiates any communication with the troubled user.
This user is running the same configuration as all the other users.
Danilo Dy
To isolate if its the ASA configuration for the troubled user is the problem or its the troubled user PC. Try using the troubled user login account to login using the PC of one of the user that are successfully connected
Dandy
