10-12-2012 08:14 PM - edited 03-04-2019 05:50 PM
I have setup a VPN server on cisco 1841 and dialed through pc, it worked fine. But when I dial through another ISP it is not working. It can establish VPN but it can't pass traffic through VPN, what may be the problem. The configuration is same and I can access Internet through this ISP.
Please help.
- mero
10-13-2012 01:49 AM
What is the local address (not the VPN address) of the PC when cannot pass traffic? What is the address of the server you're trying to access.
10-13-2012 05:11 AM
I get the private address. When I check stat sent/received traffic don't increase. What may be the problem, keeping everything same n changing ISP it works fine.
Pls help
Mero
10-13-2012 01:56 PM
I'm asking that you post here both private addresses I've asked above.
The reason it that thye could be in the same subnet, hence VPN cannot work.
10-13-2012 04:34 PM
I get dhcp public address from isp to my pc. The address is different in every connection. I am using hspda connection. The internet works fine with this.
I get private address as 192.168.10.6/24 after VPN connection and I can't find server address 10.10.10.1 through this VPN.
After using different isp connection it works fine.
- Mero
