VPN Clients not able to access DMZ
imanco671
Hello Community,
I have just setup my VPN Client. I have an inside subnet 192.168.210.0 and I have a DMZ subnet 192.168.220.0
I have my VPN users assigned an ip address from my pool 192.168.210.100 - 150
I am able to connect successfully and receive an Ip address and access servers on the 192.168.210.0 network, but I cannot access the DMZ servers.
Thanks in Advance!
43 Replies 43
Hi John,
I haved added the command for nat.
I have an outside connection I am using which is totally separate from the internal network I am trying to VPN into. Totally different carriers and IP addressing.
Here is my output:
ciscodemo(config)# sh vpn-sessiondb detail remote filter a-ipaddress 192.168.2$
Session Type: IPsec Detailed
Username     : syn-client1            Index        : 28
Assigned IP  : 192.168.230.100        Public IP    : 155.xxx.xx.35
Protocol     : IKE IPsecOverNatT
License      : IPsec
Encryption   : 3DES AES128            Hashing      : SHA1
Bytes Tx     : 0                      Bytes Rx     : 8719
Pkts Tx      : 0                      Pkts Rx      : 78
Pkts Tx Drop : 0                      Pkts Rx Drop : 0
Group Policy : DMZAccess              Tunnel Group : DMZAccess
Login Time   : 12:37:19 EDT Tue Oct 25 2011
Duration     : 0h:01m:57s
NAC Result   : Unknown
VLAN Mapping : N/A                    VLAN         : none
IKE Tunnels: 1
IPsecOverNatT Tunnels: 1
IKE:
  Tunnel ID    : 28.1
  UDP Src Port : 28708                  UDP Dst Port : 4500
  IKE Neg Mode : Aggressive             Auth Mode    : preSharedKeys
  Encryption   : 3DES                   Hashing      : SHA1
  Rekey Int (T): 86400 Seconds          Rekey Left(T): 86286 Seconds
  D/H Group    : 2
  Filter Name  :
  Client OS    : WinNT                  Client OS Ver: 4.8.01.0300
IPsecOverNatT:
  Tunnel ID    : 28.2
  Local Addr   : 0.0.0.0/0.0.0.0/0/0
  Remote Addr  : 192.168.230.100/255.255.255.255/0/0
  Encryption   : AES128                 Hashing      : SHA1
  Encapsulation: Tunnel
  Rekey Int (T): 28800 Seconds          Rekey Left(T): 28685 Seconds
  Idle Time Out: 30 Minutes             Idle TO Left : 29 Minutes
NAC:
  Reval Int (T): 0 Seconds              Reval Left(T): 0 Seconds
  SQ Int (T)   : 0 Seconds              EoU Age(T)   : 116 Seconds
  Hold Left (T): 0 Seconds              Posture Token:
  Redirect URL :
ciscodemo(config)#
John
Try this:
access-list vpn permit host 0.0.0.0
group-policy DMZAccess attributes
split-tunnel-policy excludespecified
split-tunnel-network-list value vpn
You don't have an acl assigned to your group-policy (which may be the acl you were asking about earlier). I'm not sure if the ASA defaults to allow all traffic over the tunnel if it doesn't have a policy, or if the ASA denies all traffic. The above will force all traffic over the tunnel, so let's see if this helps.
HTH, John *** Please rate all useful posts ***
I have executed those command, but still no luck.
Sorry for having such a crazy issue.
John
Are you disconnecting from the VPN and reconnecting after the change?
yes, I have been, I have also been doing a write mem on my ASA after every change.
Can you draw up a diagram of how you're laid out....I seriously don't see a problem with the config unless I'm just missing something. Is there anything between your ASA and the server in the dmz? Another router/firewall/switch? You should be able to connect and ping the device in the DMZ with no issue as long as you're not natting.
There is a PIX firewall between my ASA and the internet. I have allows all traffic to pass to my ASA. I would not be able to RDP to the 192.168.210.11 server if something was being blocked.
Also, There is no firewall between my laptop and internet.
Let me lab it up and get back to you...
okay thanks John, sorry for the headach!
John
Hi John,
Have you got both the below commands enabled?
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
Kishore
I was having a similar issue with VPN user access to a secondary interface aswell. I had the config correct and it didn't work until I reconnected to anyconnect. Thanks for the tip imanco671.
Hi John,
License      : IPsec
IKE Tunnels: 1
IKE:
  Tunnel ID    : 28.1
  D/H Group    : 2
  Filter Name  :
IPsecOverNatT:
  Tunnel ID    : 28.2
NAC:
  Redirect URL :
Looks like you have a one way traffic issue here. The ASA is receiving some traffic but its not transmitting anything back to it.  Is it possible to run some debugs?
Clear the ACL counters for the DMZ access and the try to ping the server or RDP and see if the ACL hits increment. That will give us an idea whether the packets from the VPN client are actually reaching that far.
Also, can you please paste the output  of " sh nat " and "sh nat etc.
HTH,
Kishore
Note: We will  fix your issue john dont worry
Hello Kishore,
I have made sure that both commands were executed. I then tried to connect to the VPN and RDP into the DMZ server, but without luck.
I have cleared ARP and I have cleared the ACL Counters.
Here are the commands I executed on my ASA:
ciscodemo# sh nat inside
  match ip inside 192.168.210.0 255.255.255.0 outside 192.168.230.0 255.255.255.0
    NAT exempt
    translate_hits = 0, untranslate_hits = 20
  match ip inside 192.168.210.0 255.255.255.0 outside 192.168.220.0 255.255.255.0
    NAT exempt
    translate_hits = 0, untranslate_hits = 0
  match ip inside 192.168.220.0 255.255.255.0 outside 192.168.230.0 255.255.255.0
    NAT exempt
  match ip inside 192.168.210.0 255.255.255.0 DMZ 192.168.230.0 255.255.255.0
    NAT exempt
  match ip inside 192.168.210.0 255.255.255.0 DMZ 192.168.220.0 255.255.255.0
    NAT exempt
    translate_hits = 1, untranslate_hits = 0
  match ip inside 192.168.220.0 255.255.255.0 DMZ 192.168.230.0 255.255.255.0
    NAT exempt
  match ip inside 192.168.210.0 255.255.255.0 inside 192.168.230.0 255.255.255.0
    NAT exempt
  match ip inside 192.168.210.0 255.255.255.0 inside 192.168.220.0 255.255.255.0
    NAT exempt
  match ip inside 192.168.220.0 255.255.255.0 inside 192.168.230.0 255.255.255.0
    NAT exempt
  match ip inside 192.168.210.0 255.255.255.0 outside any
    dynamic translation to pool 1 (173.xxx.xxx.66 [Interface PAT])
    translate_hits = 920, untranslate_hits = 0
  match ip inside 192.168.210.0 255.255.255.0 DMZ any
    dynamic translation to pool 1 (No matching global)
    translate_hits = 33, untranslate_hits = 0
  match ip inside 192.168.210.0 255.255.255.0 inside any
  match ip inside 192.168.230.0 255.255.255.0 outside any
    dynamic translation to pool 1 (173.xxx.xx.66 [Interface PAT])
  match ip inside 192.168.230.0 255.255.255.0 DMZ any
  match ip inside 192.168.230.0 255.255.255.0 inside any
ciscodemo# sh nat dmz
  match ip DMZ host 192.168.220.10 outside any
    static translation to 173.xxx.xx.70
    translate_hits = 3122, untranslate_hits = 151
  match ip DMZ 192.168.220.0 255.255.255.0 outside any
    translate_hits = 10, untranslate_hits = 0
  match ip DMZ 192.168.220.0 255.255.255.0 DMZ any
John
Anything more I can test or try?
I am still unable allow access from VPN to DMZ.
John
