VPN Clients not able to access DMZ
imanco671
Hello Community,
I have just setup my VPN Client. I have an inside subnet 192.168.210.0 and I have a DMZ subnet 192.168.220.0
I have my VPN users assigned an ip address from my pool 192.168.210.100 - 150
I am able to connect successfully and receive an Ip address and access servers on the 192.168.210.0 network, but I cannot access the DMZ servers.
Thanks in Advance!
43 Replies 43
imanco671
Should I repost this in another discussion area?
I am using my ASDM to manage the VPN too.
I have tried to alter the group policy too  without success.
I have no idea of what to adjust or add. I was beginning to think there was an ACL to add, but that did not work either.
John
It could have some thing to do with the iOS or device type
Can you not get to the dmz from the Internet not using the VPN ?
Are these subnets on the same physical interface? Did you try enabling "same-security interface permit intra-interface"? . Also make sure you have appropriate ACLs configured on both interfaces to permit/deny what you want.
Note: This should carefully be used as sometimes you might have 2 seperate customer DMZ's with same security-level then they will be able to see each other's traffic if acl's not in place.
on a side note
Can  I make a quick suggestion here? I would recommend using a different IP block for the remote users. maybe say 172.16.0.0 or 172.31.0.0 whatever  anything that doesn't clash with the 192.168.210.0/24 subnet.
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807e0aca.shtml#ra-sol-3
HTH,
Kishore
Please rate if helpful
Hi James,
Yes I can get to a webserver hosted on the DMZ from the internet.
Hi Kishore,
The DMZ and the INSIDE are on separate interfaces ethernet0/1 and ethernet0/2, the ACLs are correct from a server within the INSIDE interface. This server can RDP to the DMZ without issues, but the DMZ cannot access the INSIDE subnet.
These VPN users are people who need access to only the DMZ, should I just have them VPN into the DMZ? How can I configure the VPN using ASDM to login to the DMZ only?
I think this would be easier, but I just dont know how.
Hello Community,
I have enabled slit tunneling, so my vpn client can get to the internet from his/her laptop. I just still cannot RDP into the DMZ server. I can RDP into the INSIDE server.
(I am also able to RDP into the DMZ server from the INSIDE server)
Here is my sh run for the access list section and nating:
access-list outside_in extended permit tcp any host 173.xxx.xx.70 eq www
access-list nonat extended permit ip 192.168.210.0 255.255.255.0 192.168.220.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip any 192.168.210.0 255.255.255.0
access-list vpn-dmz standard permit 192.168.220.0 255.255.255.0
access-list vpn-dmz standard permit 192.168.210.0 255.255.255.0
access-list vpn-dmz standard permit 192.168.0.0 255.255.255.0
pager lines 24
mtu outside 1500
mtu DMZ 1500
mtu inside 1500
ip local pool DMZPool 192.168.220.100-192.168.220.125 mask 255.255.255.0
ip local pool DMZ-Pool 192.168.210.100-192.168.210.150 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-615.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
global (DMZ) 1 interface
nat (DMZ) 1 192.168.220.0 255.255.255.0
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 192.168.210.0 255.255.255.0
static (DMZ,outside) 173.xxx.xxx.70 192.168.220.10 netmask 255.255.255.255
access-group outside_in in interface outside
It's hard to tell from your partial config how you have your split tunnel, and how you have designated your networks for the VPN connection. Can you post the full config?
Things that need to be checked:
- Your VPN connection needs to know that both the inside and DMZ networks should be reached from the client through the VPN. A common problem in such a scenario would be to only tell the VPN setup about the inside network, and then the client doesn't know how to route the request to go to the DMZ server.
- You may need a non-nat for the DMZ to VPN connections. Since you have a static NAT on your DMZ connection, you might be confusing the VPN connection setup. I would recommend excluding connections between your DMZ and your VPN group from NAT. I note that you have created the nonat ACL, but you have not applied it to your DMZ interface. You need a line that says:  nat (DMZ) 0 access-list nonat
Hi Dan,
I added the nat 0 command, but that did not help the VPN client get to the DMZ.
Anythign else I can try?
ASA Version 8.0(4)
hostname ciscodemo
domain-name a.com
enable password U.Tf7Hhd3h encrypted
passwd 2KFQnI.2KYOU encrypted
names
interface Ethernet0/0
nameif outside
security-level 0
ip address 173.xxx.xx.66 255.255.255.224
interface Ethernet0/1
nameif DMZ
security-level 50
ip address 192.168.220.222 255.255.255.0
interface Ethernet0/2
nameif inside
security-level 100
ip address 192.168.210.222 255.255.255.0
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns server-group DefaultDNS
domain-name aral.com
pager lines 24
mtu outside 1500
mtu DMZ 1500
mtu inside 1500
arp timeout 14400
static (DMZ,outside) 173.xxx.xx.70 192.168.220.10 netmask 255.255.255.255
router rip
network 192.168.210.0
network 192.168.220.0
passive-interface DMZ
version 2
no auto-summary
route outside 0.0.0.0 0.0.0.0 173.xxx.xx.65 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.210.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set security-association lifetime seconds 28800
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set security-association lifetime kilobytes 4608000
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto map DMZ_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map DMZ_map interface DMZ
crypto isakmp enable outside
crypto isakmp enable DMZ
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
enable outside
svc enable
group-policy DfltGrpPolicy attributes
split-tunnel-policy tunnelspecified
split-tunnel-network-list value vpn-dmz
group-policy DMZAccess internal
group-policy DMZAccess attributes
dns-server value 10.10.10.11 10.10.10.22
vpn-tunnel-protocol IPSec
default-domain value a.com
username syn-client4 password dIb97qfm6shciivc encrypted privilege 0
username syn-client4 attributes
vpn-group-policy DMZAccess
username syn-client5 password dIb97qfm6shciivc encrypted privilege 0
username syn-client5 attributes
username syn-client2 password dIb97qfm6shciivc encrypted privilege 0
username syn-client2 attributes
username syn-client3 password dIb97qfm6shciivc encrypted privilege 0
username syn-client3 attributes
username syn-client1 password dIb97qfm6shciivc encrypted privilege 0
username syn-client1 attributes
tunnel-group DMZAccess type remote-access
tunnel-group DMZAccess general-attributes
address-pool DMZ-Pool
default-group-policy DMZAccess
tunnel-group DMZAccess ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
policy-map global_policy
class inspection_default
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect icmp
  inspect ftp
  inspect ipsec-pass-thru
  inspect http
  inspect pptp
service-policy global_policy global
prompt hostname context
Cryptochecksum:b20ed392a3bd1a057cc32e41683f55e6
: end
Hi Dan,
Do you need more info from me? Should I just make the VPN clients login directly to the DMZ subnet, I think this would solve many issues too. But I still would like a VPN group who can log directly into the DMz and another group to get logged into the INSIDE subnet.
Hi Community,
Can anyone suggest how I can connect to the DMZ? I have researched and tried everything in the ASDM, maybe its not possible?
I have a test laptop with VPN ready to test anything. Even if I give the laptop an IP address range from my DMZ, it will not connect to the DMZ server. I have made sure the routes are there on the laptop.
Im stumpted......
John,
I'm a little confused as to what the next few lines are for:
nat (inside) 0 access-list nonat
The DMZ is on the 192.168.22.0/24 subnet, correct? If that's the case, the only acl that you need to bypass nat is your nonat acl.
The other thing that I'm in agreement with is the fact that you really should put your ip pool on a different subnet altogether.
ip local pool DMZ-Pool 192.168.210.100-192.168.210.150 mask 255.255.255.0 <-- What is this one for?
I'm not sure you need the following:
Also, you're not really doing anything with the group-policy and split tunneling. You should put your split tunneling policy (from the DfltGrpPolicy) under the DMZAccess attributes section.
Lastly, let's say you put the remote users on 172.16.30.0/24 and your pool assigns that. I put a static route on my ASA pointing to my router. (route outside 172.16.30.0 255.255.255.0 192.168.201.1) That'll push traffic that belongs to the VPN back out of the ASA. Otherwise, because you're giving an address out of the pool that you use locally, it may try to route local instead of away from the ASA.
John
HTH, John *** Please rate all useful posts ***
Hi John,
I have added the global (DMZ) 1 interface, so my DMZ servers can access the internet.
I have added nat (DMZ) 0 access-list nonat - Dan recommended it
This is just another pool that I tried using, my VPN  clients are not using this pool, I have just left it inactive, The  192.168.210.0 is the pool I am using for them.
I am not sure of the above, I just used the ASDM wizard to configure the VPN. If I need to delete, I will...
Would you like me to issue the above commands?
okay so you suggest making up a new subnet for the VPN  users to use. Using a new subnet not assigned to any interface on my  ASA and then setup routing?
Thanks for the reply John,
Sorry, I am a beginner....I am trying to grasp everything, but can understand you though......
John,
This will be enough for your dmz hosts to get to the internet.
I think ASDM may have put in the crypto map because of the global command (I can't verify this though). It applied it to the dmz interface which you don't need.
You need to put the above commands under the group-policy that your users reference in the VPN client. (group-policy DMZAccess attributes)
Yes I do, and that's correct.
John
Hi John,
I have taken split tunneling off, I have also taken off the "nat (DMZ) 0 access-list nonat" line.
I have added a new pool called DMZ230 which is on a new subnet of 192.168.230.0
From you earlier replys, I see you now want me to add a static route on my ASA?
Should I enter the below?
route outside 192.168.230.0 255.255.255.0 192.168.210.1
The 192.168.220.1 is my internal router which is not implemented into the network yet, Should I just use my 192.168.210.0 interface on the ASA which is 192.168.210.222?
My understanding now is: VPN users assigned to new subnet, this subnet has to be routed to the INSIDE interface (not the DMZ interface), then the users should be able to access the DMZ.
Not trying to doubt anything, but do I have to define this new vpn subnet (192.168.230.0) somewhere else on my ASA too?
John,
You'll need to assign the local pool to your DMZAccess group that you created for the vpn users to use. Other than that, you don't need to reference this subnet anywhere else in the ASA.
You should put the static route pointing to whatever your default gateway is for the ASA. If the gateway for the ASA is 192.168.220.1, then that's what you'd put for this static route. If you have any other devices that need to see this subnet like a L3 switch, other routers, etc, they'll need to know to get to the 192.168.230.0/24 subnet to go to your inside interface on the ASA. Does that make sense?
John
