VPN configuration between two routers in a same router
ashz14387
R1 configuration are,
! Last configuration change at 06:59:12 UTC Thu Aug 10 2023
version 15.2
hostname R1
boot-start-marker
boot-end-marker
enable password Network@123
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
ip flow-cache timeout active 1
ip name-server 8.8.8.8
no ipv6 cef
username admin password 0 Network@123
ip tcp synwait-time 5
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key Network@123 address 172.16.1.2
crypto isakmp key Network@123 address 192.168.1.2
crypto isakmp key Network@123 address 106.198.0.26
crypto ipsec transform-set TS esp-3des esp-md5-hmac
mode tunnel
crypto map CMAP 10 ipsec-isakmp
set peer 192.168.1.2
set transform-set TS
match address VPN-TRAFFIC
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface FastEthernet0/0
ip address 10.200.200.2 255.255.255.0
duplex full
crypto map CMAP
interface FastEthernet1/0
ip address 168.254.1.1 255.255.255.0
ip flow ingress
duplex full
interface FastEthernet2/0
ip address 172.16.1.1 255.255.255.0
ip flow ingress
duplex full
crypto map CMAP
interface FastEthernet3/0
no ip address
ip flow ingress
shutdown
duplex full
interface FastEthernet4/0
no ip address
ip flow ingress
shutdown
duplex full
interface FastEthernet5/0
no ip address
shutdown
duplex full
interface FastEthernet6/0
no ip address
shutdown
duplex full
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.200.200.1
ip access-list extended VPN-TRAFFIC
permit ip 168.254.1.0 0.0.0.255 20.20.10.0 0.0.0.255
snmp-server community public RO
snmp-server community private RW
snmp ifmib ifindex persist
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login local
transport input telnet
line vty 5 15
login local
end
R2 configurations are,
! Last configuration change at 07:00:07 UTC Thu Aug 10 2023
version 15.2
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
encr 3des
hash md5
group 2
crypto isakmp key Network@123 address 172.16.1.1
crypto isakmp key Network@123 address 10.200.200.2
mode tunnel
set peer 10.200.200.2
interface Loopback0
ip address 192.168.1.2 255.255.255.0
duplex full
crypto map CMAP
ip address 172.168.1.1 255.255.255.0
duplex full
ip address 172.16.1.2 255.255.255.0
ip flow ingress
duplex full
crypto map CMAP
no ip address
ip flow ingress
shutdown
duplex full
no ip address
ip flow ingress
shutdown
duplex full
no ip address
shutdown
duplex full
no ip address
shutdown
duplex full
no ip http server
permit ip 20.20.10.0 0.0.0.255 168.254.1.0 0.0.0.255
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login local
line vty 5 15
login local
end
Where did i gone wrong
Hello
A few things look incorrect
Your crypto map peers are incorrect, your interesting traffic ACL doesn't reflect RTR1 & RTR2 lan networks and you do not have any specific route to each others lan subnet
Try the following:
RTR1
no set peer 192.168.1.2
set peer 172.16.1.2
no permit ip 168.254.1.0 0.0.0.255 20.20.10.0 0.0.0.255
permit ip 168.254.1.0 0.0.0.255 172.168.1.0 0.0.0.255
ip route 172.168.1.0 0.0.0.255 172.16.1.2
RTR2
set peer 172.16.1.1
no permit ip 20.20.10.0 0.0.0.255 168.254.1.0 0.0.0.255
permit ip 172.168.1 0.0.0.255 168.254.1.0 0.0.0.255
ip route 168.254.1.0 255.255.255.0 172.16.1.1
Kind Regards
Paul
what about crypto isakmp key command
