VPN logs and details
itdsmartnet
hi,
I have configured ASA 5550 as a VPN server. I want a software from which i get information which user is logged at what time, and this software maintains history also.
you may check on which specific logs you want to receive here
http://www.cisco.com/en/US/docs/security/asa/asa80/system/message/logmsgs.html
and you may enable the logging 113004 for example
logging message 113004
9 Replies 9
Giuseppe Larosa
Hello Waseem,
configuring a syslog server and an adeguate level of logging should be enough.
Kiwi syslog is a good syslog server that we use and it should be freeware
Hope to help
Giuseppe
hi Giuseppe
i have configured syslog server but i am unable to see any log. The following commands are entered under ASA 5550 for logging.
"logging on" , "logging host inside 10.101.5.199" Is there any other command in ASA required for proper logging?
you should also specify on which system log messages should be sent to the syslog server such as
logging timestamp
logging buffered debugging
logging trap debugging
logging asdm debugging
logging facility 21
http://www.cisco.com/en/US/docs/security/asa/asa72/system/message/logconf.html#wp1066629
Thanks for your reply, Actually i have configured ASA 5550 as a VPN server and all remote clients are connected to it. Actually i want only those logs which tells me which user connected time and logged off time.
hi,
one thing , how can i filter the log. "logging message " will enable or disable the log for that event id. i only want log to appear on syslog with event id e.g 113004.
logging message level <0-7>
is that what you are looking for?
hi,
actually i only want log for vpn nothing else. i have configured ASA5550 as a vpn server and my remote user and connected to it using cisco vpn clients. just want login time and logout time in syslog nothing else.
im not sure of which of these logs you are looking to filter
113019
721018
721019
722007
722009
722012
