VPN Modules - Site to Site VPN
tech_trac
Are any VPN Modules required to configure site-to-site VPN on Cisco ISR Routers ? What are VPN modules for ?
Laurent Aubert
ISR (1800/2800/3800) have a build-in encryption acceleration card but require Cisco IOS Software Advanced Security or higher feature set to enable it
If you want the best performance for those boxes, AIM-VPN modules are recommended:
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/data_sheet_vpn_aim_for_18128003800routers.html
Laurent.
Thanks.
Could you please also mention the difference between the performance on built-in encryption acceleration card and the AIM-VPN Modules for e.g. in case of 2821 routers.
Are the VPN modules visible from outside the router after installation or are they seated inside the router.
