VPN Question ????
afzaalq007
HI
I want to know about VPN's becuse i am want to learn about it.
Introduction to VPN ??
Cisco Plateform minimum (router and IOS) on which they are supported.
please foeward me some usefull link about the VPNs
Thnaks
6 Replies 6
jolmo
Level 4
Level 4
This might help:
"How Virtual Private Networks Work"
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_tech_note09186a0080094865.shtml
Also check useful links at the end of that document.
Thanks for the Ans.
I want to know about the IOS in which IOS they are supported
I have C-2500 and C-2600 router can test on these router just a VPN between two router,
Almost every IOS release supports VPN. But you have to use an IP PLUS IPSEC or ENTERPRISE PLUS IPSEC Feature Set in order to support VPN.
Thanks for the Ans !!!!
I want to config VPN b/t two router one is of C2503 with IOS ver 11.0(10c). and other one is the C2621 with IOS ver 12.2(8)T5.
I need some basic commands to creat a vpn betweeen these router
C2500 VPN C2621
C2500 VPN C2621
Pls give the full IOS name...b'coz it may not have the features.Other way round if you are not able to get the required IOS is that you can configure 2621 as VPN server and configure your PC as Dial-in client.
You can check if your IOS supports the function by going to following link:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
The following is an useful link for VPNs
http://www.cisco.com/univercd/cc/td/doc/product/core/7100/swcg/index.htm
Hope that will help
Pls rate helpful posts.
JD
