11-02-2009 05:23 PM - edited 03-04-2019 06:35 AM
Somebody knows if it possible to do vpn s2s with multiple internet connections (adsl) ?. I want to make one big bw pipe i think maybe with bridging.
Any ideas?
Thanks in advance.
11-02-2009 07:02 PM
You can create one tunnel per connection and load-balance your traffic over those tunnels by installing multiple route into the routing table.
If you bridge, STP will block all your connection except one.
Laurent.
Log in to Community
